跳转到主内容
How to Upgrade the Expandable Storage in Your PlayStation 5 Slim
你所需要的
  1. How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Prepare your PlayStation for disassembly: 步骤 1 中的图像 1,3 How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Prepare your PlayStation for disassembly: 步骤 1 中的图像 2,3 How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Prepare your PlayStation for disassembly: 步骤 1 中的图像 3,3
    • Before starting your repair:
    • Shut down your console.
    • Unplug all cables and accessories.
    • Remove any stands supporting your device.
  2. How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Lay your PlayStation down: 步骤 2 中的图像 1,1
    • Lay your PlayStation on its side so the right side covers are facing up.
  3. How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Remove the fan and SSD cover: 步骤 3 中的图像 1,3 How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Remove the fan and SSD cover: 步骤 3 中的图像 2,3 How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Remove the fan and SSD cover: 步骤 3 中的图像 3,3
    • The upper cover is secured with hooks along the back edge and clips along the front edge.
    • Firmly pull up the front edge of the cover to release the clips.
    • You'll hear distinct "pops" as the clips disengage.
    • Remove the cover.
    • To reinstall the cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the two clips.
  4. How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Remove the expansion slot cover screw: 步骤 4 中的图像 1,2 How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Remove the expansion slot cover screw: 步骤 4 中的图像 2,2
    • Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
  5. How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Remove the expansion slot cover: 步骤 5 中的图像 1,3 How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Remove the expansion slot cover: 步骤 5 中的图像 2,3 How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Remove the expansion slot cover: 步骤 5 中的图像 3,3
    • Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
  6. How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Remove the SSD screw: 步骤 6 中的图像 1,2 How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Remove the SSD screw: 步骤 6 中的图像 2,2
    • Use a Phillips screwdriver to remove the 10.9 mm‑long SSD screw securing the spacer.
  7. How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Move the spacer: 步骤 7 中的图像 1,3 How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Move the spacer: 步骤 7 中的图像 2,3 How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Move the spacer: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Multiple indents along the expansion slot allow for compatibility with any sized SSD. Each indent is labeled with its corresponding size.
    • Use tweezers or your fingers to move the spacer to its proper indent based on the size of your SSD.
    • Do not install the SSD without the spacer.
  8. How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Fasten the SSD: 步骤 8 中的图像 1,2 How to Upgrade the Expandable Storage in Your PlayStation 5 Slim, Fasten the SSD: 步骤 8 中的图像 2,2
    • Make sure your SSD is compatible with your PlayStation and has a heat-dissipation mechanism such as a heatsink or thermal pad.
    • Insert the SSD into its M.2 socket at a slight downward angle.
    • Both the SSD and M.2 socket are keyed, which means the SSD only fits into the socket one way.
    • It's normal for the SSD to sit up at an angle before it's secured in place
    • With one hand, push the SSD down so its cutout is aligned on top of the spacer.
    • With your free hand, use your Phillips screwdriver to tighten the SSD screw.
    • Do not overtighten this screw, as doing so may damage the SSD.
结论
To reassemble your device, follow these instructions in reverse order starting with the expansion slot cover.
If it's your first time using the SSD with your PlayStation, you'll need to format it after installation.
If you're moving games to your new SSD, follow Sony's guide.
另外一个人完成了本指南。
Spencer Day
于09/14/22注册
59,654 声望
创作了430篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,895篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 91
过去 30 天: 393
总计 1,691
