跳转到主内容
How to Install a Heatsink on an M.2 SSD
你所需要的
  1. How to Install a Heatsink on an M.2 SSD, Prepare the first thermal pad: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    • The heatsink uses thermal pads to dissipate heat from either side of the blade SSD. The thermal pads may come with plastic liners on each side, so make sure all are removed before use.
    • Use a pair of tweezers to peel one side of protective film away from one of the thermal pads.
  2. How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: 步骤 2 中的图像 1,3 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: 步骤 2 中的图像 2,3 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: 步骤 2 中的图像 3,3
    • Align the exposed side of the thermal pad with the bottom tray section of the heatsink assembly.
    • Lay the thermal pad down so it covers the tray evenly.
    • Use your finger to lightly press down on the thermal pad to adhere it to the surface.
  3. How to Install a Heatsink on an M.2 SSD, Prepare the second thermal pad: 步骤 3 中的图像 1,1
    • Use a pair of tweezers to peel one side of protective film away from the remaining thermal pad.
  4. How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: 步骤 4 中的图像 1,3 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: 步骤 4 中的图像 2,3 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: 步骤 4 中的图像 3,3
    • Align the exposed side of the thermal pad with the top section of the heatsink.
    • Lay the thermal pad down so it covers the top section evenly.
  5. How to Install a Heatsink on an M.2 SSD, Remove the bottom thermal pad liner: 步骤 5 中的图像 1,1
    • Use a pair of tweezers to remove the plastic liner from the thermal pad in the tray.
    • The thermal pad might lift up from the tray as the liner is removed—this is normal. Use your finger to keep the pad in the tray.
  6. How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: 步骤 6 中的图像 1,3 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: 步骤 6 中的图像 2,3 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: 步骤 6 中的图像 3,3
    • Lay the M.2 SSD into the tray, the side with the most chips facing up.
    • Make sure the SSD is centered in the tray. The tray shouldn't cover the contacts or the screw cutout.
  7. How to Install a Heatsink on an M.2 SSD, Remove the top thermal pad liner: 步骤 7 中的图像 1,1
    • Use a pair of tweezers to remove the plastic liner from the thermal pad on the heatsink's top section.
    • The thermal pad might lift up from the heatsink as the liner is removed—this is normal. Use your finger to keep the pad in place.
  8. How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: 步骤 8 中的图像 1,3 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: 步骤 8 中的图像 2,3 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: 步骤 8 中的图像 3,3
    • Align the top heatsink section over the SSD and the tray.
    • Firmly press the two halves together. You'll feel it "snap" into place.
  9. How to Install a Heatsink on an M.2 SSD, Check the alignment: 步骤 9 中的图像 1,1
    • For the SSD to fit in a desktop PC or a PlayStation 5, the heatsink needs to be centered on the SSD.
    • Make sure that the heatsink is close to the screw cutout but doesn't overhang it.
    • If you're having trouble installing your SSD, you may have to slightly adjust the heatsink's position.
    • Use your fingers to slide the SSD between the two halves of the heatsink assembly until fitment is just right.
结论
Installation didn’t go as planned? Check out our Computer Hardware Answers community or PlayStation 5 Answers community for troubleshooting help.
8等其他人完成本指南。
Carsten Frauenheim
于03/10/20注册
155,724 声望
创作了439篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,649篇指南
4指南评论
If your SSD has a big "warranty void if removed" sticker over the chips, do you have to remove it? Or can you stick the thermal pad over that sticker?
shamino - 回复
You can leave the sticker on the SSD! Just make sure to remove any adhesive liners on the thermal pad.
Carsten Frauenheim -
I just bought predator gm7000 ssd with heatsink. The ssd only come with one thermal pad on top to be use with the heatsink. Do i need to get another thermal pad for bottom?
afiqtobi9 - 回复
This is just a generic guide, so not every step applies to every situation. I've checked your mentioned SSD and it comes with a custom heatsink for it, which means you don't need another one. Thermal pads only help if they're touching a surface (i.e. a metal sheet) for heat transfer. Since this isn't how yours is build/installed, a second pad would be basically pointless. Hope this helps :)
Kongoduff -
添加评论
浏览统计数据:
过去 24 小时: 95
过去 7 天: 609
过去 30 天: 2,463
总计 94,709
