跳转到主内容
How to Replace a Gigabyte Geforce RTX 2060 Graphics Card
Amirali Rahimian
Amirali Rahimian 另一个贡献者
最后更新于 June 21, 2024
15 - 30 分钟
中等
动态照片拍摄
需要更多图片
The following replacement guide explains how to replace your Gigabyte Geforce RTX 2060 graphics card with any other GPU of your choice.
Every computer needs a graphics card to properly function. The graphics card is what is used to render the things you see on screen, so whether your current GPU is defective/damaged or even outdated, this guide will help you get your computer working properly again.
Prior to beginning the guide, be sure to power down your device and disconnect from the power chord. Additionally, work on a hard surface and avoid working on a carpeted area.
你所需要的
工具
  1. How to Replace a Gigabyte Geforce RTX 2060 Graphics Card, Graphics Card: 步骤 1 中的图像 1,3 How to Replace a Gigabyte Geforce RTX 2060 Graphics Card, Graphics Card: 步骤 1 中的图像 2,3 How to Replace a Gigabyte Geforce RTX 2060 Graphics Card, Graphics Card: 步骤 1 中的图像 3,3
    • Shut down and unplug everything from the back of your PC.
    • Flip the power supply switch so that it is OFF.
    • Take off the side panel by removing the screws that lock it in place.
    • Your side panel screws will most likely be in different locations than the screws in the picture, depending on your PC case.
    • Before proceeding, make sure to ground yourself by touching any metal part of the PC case. This releases any built up static charge that could permanently damage your internal parts.
  2. How to Replace a Gigabyte Geforce RTX 2060 Graphics Card: 步骤 2 中的图像 1,2 How to Replace a Gigabyte Geforce RTX 2060 Graphics Card: 步骤 2 中的图像 2,2
    • Push down on the lock clip located on the PCIe cable.
    • Unplug the PCIe cable by gently pulling it out.
  3. How to Replace a Gigabyte Geforce RTX 2060 Graphics Card: 步骤 3 中的图像 1,1
    • Remove the small Phillips #0 mounting screw(s) that connect the GPU onto the back of the PC case.
    • Keep the small screw(s) in a safe place where they can not be lost.
  4. How to Replace a Gigabyte Geforce RTX 2060 Graphics Card: 步骤 4 中的图像 1,3 How to Replace a Gigabyte Geforce RTX 2060 Graphics Card: 步骤 4 中的图像 2,3 How to Replace a Gigabyte Geforce RTX 2060 Graphics Card: 步骤 4 中的图像 3,3
    • Push down on the lock tab located beside the GPU slot on the motherboard.
    • Remove the graphics card by gently pulling it out from the GPU slot. Use both hands for extra caution.
    • The screwdriver was only used to point at lock tab since it can sometimes be hard to spot.
  5. How to Replace a Gigabyte Geforce RTX 2060 Graphics Card: 步骤 5 中的图像 1,2 How to Replace a Gigabyte Geforce RTX 2060 Graphics Card: 步骤 5 中的图像 2,2
    • Take your new graphics card and carefully line it up with the GPU slot on the motherboard.
    • Keep in mind where the gap in the gold pins is located.
  6. How to Replace a Gigabyte Geforce RTX 2060 Graphics Card: 步骤 6 中的图像 1,2 How to Replace a Gigabyte Geforce RTX 2060 Graphics Card: 步骤 6 中的图像 2,2
    • Once it is perfectly lined up, gently push the graphics card into the slot until a click is heard.
结论
To reassemble your device, follow steps 1-3 in reverse order.
8等其他人完成本指南。
团队
1指南评论
Should not be difficulty set as easy?
Viktor - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 99
过去 30 天: 841
总计 16,885
