跳转到主内容
How to Patch a Small Hole in Drywall
Jessica Yurgin
Jessica Yurgin2 其他贡献者
最后更新于 July 15, 2020
4 - 6 小时
简单
需要更好的图片
It is not uncommon to have minor holes in your drywall from kids, accidents, or simple wear and tear. This guide will help you fix those holes and make your wall look brand-new!
In the guide, you will go through the steps of drilling, filling, and painting a small hole in your damaged drywall.
  1. How to Patch a Small Hole in Drywall, How to Patch a Small Hole in Drywall: 步骤 1 中的图像 1,3 How to Patch a Small Hole in Drywall, How to Patch a Small Hole in Drywall: 步骤 1 中的图像 2,3 How to Patch a Small Hole in Drywall, How to Patch a Small Hole in Drywall: 步骤 1 中的图像 3,3
    • If the initial hole is smaller than a quarter, use a screwdriver to carefully make the hole larger. This will allow the patching plaster to fill better.
    • Place painter's tape around the hole so the plaster does not get onto places it does not belong.
  2. How to Patch a Small Hole in Drywall: 步骤 2 中的图像 1,3 How to Patch a Small Hole in Drywall: 步骤 2 中的图像 2,3 How to Patch a Small Hole in Drywall: 步骤 2 中的图像 3,3
    • Dip the chisel scraper into the patching plaster, and begin to fill the hole. Use a gentle pressing motion to fill. Press multiple layers of the plaster until the entire hole is filled.
    • Let the wall dry for at least three hours.
  3. How to Patch a Small Hole in Drywall: 步骤 3 中的图像 1,2 How to Patch a Small Hole in Drywall: 步骤 3 中的图像 2,2
    • After the filling is fully dry, take a damp sponge and gently remove any access plaster from the wall. First, start with the surface surrounding the hole.
    • After the wall is clean of excess plaster, carefully wipe the plaster from inside the wall until it is even with the original surface.
  4. How to Patch a Small Hole in Drywall: 步骤 4 中的图像 1,3 How to Patch a Small Hole in Drywall: 步骤 4 中的图像 2,3 How to Patch a Small Hole in Drywall: 步骤 4 中的图像 3,3
    • Remove the painters tape from the wall.
    • Dip the paint sponge in paint, and paint the wall with the original color of the wall.
    • Let it dry accordingly.
结论
Hopefully you found this guide easy and helpful for fixing any minor dents in your drywall. Good luck!
2等其他人完成本指南。
Jessica Yurgin
于01/19/16注册
178 声望
撰写一个指南
团队
2指南评论
Great guide to fixing plasterboard. I normally just try to fit a scrap piece of plasterboard in the hole when fixing it, but using cardboard is a much easier and better idea. I can cut it with scissors and won't have to make the whole bigger to screw the piece of drywall in. If you need help with drywall repair in your home visit: https://www.plasterroanoke.com
Kim - 回复
Very nice… I really like your blog. Very useful information.
Century Drywall - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 60
总计 5,502
