跳转到主内容
加入维修社区 - 创建账户
How to Open Your Logitech G305
你所需要的
    1. How to Open Your Logitech G305, Turn off your mouse: 步骤 1 中的图像 1,2 How to Open Your Logitech G305, Turn off your mouse: 步骤 1 中的图像 2,2
      • Slide your mouse's power switch to the left so it's in the OFF position.
      • A red indicator should be visible beneath the switch.
      • Throughout your repair, it may be helpful to lay your mouse on a soft cloth to stabilize it and prevent damage while you work.
      询问修复机器人
      添加评论
    1. How to Open Your Logitech G305, Remove the mouse feet: 步骤 2 中的图像 1,2 How to Open Your Logitech G305, Remove the mouse feet: 步骤 2 中的图像 2,2
      • The feet are secured to the bottom of the mouse with adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
      • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
      • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
      • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
      询问修复机器人
      添加评论
    2. How to Open Your Logitech G305: 步骤 3 中的图像 1,3 How to Open Your Logitech G305: 步骤 3 中的图像 2,3 How to Open Your Logitech G305: 步骤 3 中的图像 3,3
      • The feet have two layers—a rubberized one and an adhesive pad underneath.
      • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
      • Carefully slide the point of a spudger under one of the feet, making sure it goes under both the foot and its adhesive pad.
      • If you're just removing the feet to open the mouse, you don't need to remove the circular one below the power switch.
      • Gently slide the spudger farther under the foot and lift to remove it.
      • If the rubber layer separates from its adhesive pad, use the same process to remove the pad.
      添加评论
    3. How to Open Your Logitech G305: 步骤 4 中的图像 1,3 How to Open Your Logitech G305: 步骤 4 中的图像 2,3 How to Open Your Logitech G305: 步骤 4 中的图像 3,3
      • Repeat the previous step to remove the remaining feet.
      询问修复机器人
      添加评论
    4. How to Open Your Logitech G305, Reassembly information: 步骤 5 中的图像 1,3 How to Open Your Logitech G305, Reassembly information: 步骤 5 中的图像 2,3 How to Open Your Logitech G305, Reassembly information: 步骤 5 中的图像 3,3
      • To install a new foot:
      • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
      • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
      • If there's any adhesive residue left, use isopropyl alcohol and a microfiber cloth to remove it. Allow the surface to completely dry.
      • Remove the feet from their backing and firmly press them into place.
      询问修复机器人
      添加评论
    1. How to Open Your Logitech G305, Remove the battery: 步骤 6 中的图像 1,3 How to Open Your Logitech G305, Remove the battery: 步骤 6 中的图像 2,3 How to Open Your Logitech G305, Remove the battery: 步骤 6 中的图像 3,3
      • Press down on the top cover just above the Logitech logo and slide it back to remove it.
      • When reinstalling the cover, you should feel and hear a "click" as it slides into place.
      询问修复机器人
      添加评论
    2. How to Open Your Logitech G305: 步骤 7 中的图像 1,3 How to Open Your Logitech G305: 步骤 7 中的图像 2,3 How to Open Your Logitech G305: 步骤 7 中的图像 3,3
      • Lift the end of the AA battery near the back of the mouse and remove it.
      • To install a new battery, slide the negative (-) end into the recess so it's near the front of the mouse and push the battery into place.
      询问修复机器人
      添加评论
    1. How to Open Your Logitech G305, Open your mouse: 步骤 8 中的图像 1,2 How to Open Your Logitech G305, Open your mouse: 步骤 8 中的图像 2,2
      • Use a Phillips screwdriver to remove the four 5.3 mm‑long screws securing the bottom shell.
      询问修复机器人
      添加评论
    2. How to Open Your Logitech G305: 步骤 9 中的图像 1,2 How to Open Your Logitech G305: 步骤 9 中的图像 2,2
      • With one hand, firmly hold the bottom shell in place.
      • With your free hand, lift the front of the top shell to partially separate it.
      • Don't try to fully separate the top shell, as the back is still clipped in.
      询问修复机器人
      添加评论
    3. How to Open Your Logitech G305: 步骤 10 中的图像 1,3 How to Open Your Logitech G305: 步骤 10 中的图像 2,3 How to Open Your Logitech G305: 步骤 10 中的图像 3,3
      • With one hand, firmly grip the top shell.
      • With your free hand, insert the flat end of a spudger between the top and bottom shells near the rear of the mouse.
      • Slide the spudger towards the rear of the mouse while pulling the top shell up and toward the front to separate the shells.
      • If the shells don't separate, repeat the process on the other side of the mouse.
      询问修复机器人
      添加评论
    4. How to Open Your Logitech G305: 步骤 11 中的图像 1,3 How to Open Your Logitech G305: 步骤 11 中的图像 2,3 How to Open Your Logitech G305: 步骤 11 中的图像 3,3
      • Don't try to fully remove the top shell yet, as two cables still connect it.
      • Lift the top shell up and flip it over the right edge of the mouse, being careful not to strain the cables.
      • The top shell should stay slightly propped up.
      询问修复机器人
      添加评论
    5. How to Open Your Logitech G305: 步骤 12 中的图像 1,3 How to Open Your Logitech G305: 步骤 12 中的图像 2,3 How to Open Your Logitech G305: 步骤 12 中的图像 3,3
      • Use tweezers to firmly grip the short edges of the battery cable connector on the bottom right corner of the board.
      • Pull the connector straight up and out of its socket.
      • If you're having trouble, rock the connector side-to-side to help loosen it.
      • During reassembly, push down on the edges of the connector with the flat end of a spudger until it's fully seated in the socket.
      询问修复机器人
      添加评论
    6. How to Open Your Logitech G305: 步骤 13 中的图像 1,2 How to Open Your Logitech G305: 步骤 13 中的图像 2,2
      • Lay the top shell flat on your workspace to the right of the mouse.
      询问修复机器人
      添加评论
    7. How to Open Your Logitech G305: 步骤 14 中的图像 1,3 How to Open Your Logitech G305: 步骤 14 中的图像 2,3 How to Open Your Logitech G305: 步骤 14 中的图像 3,3
      • Use tweezers to firmly grip the short edges of the top buttons connector on the right edge of the board.
      • During reassembly, push down on the short edges of the connector with the flat end of a spudger until it's fully seated in the socket.
      询问修复机器人
      添加评论
    8. How to Open Your Logitech G305: 步骤 15 中的图像 1,1
      • The top and bottom shells are now fully separated.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
Spencer Day
于09/14/22注册
199,518 声望
创作了1,243篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了72,229篇指南
8指南评论
Muito bom, consegui consertar o problema do botão esquerdo e ficou novinho, fiz uma limpeza e Show .
HighTechGG - 回复 分享
Hey, there is a little tab at the back of the mouse on step 10 that seems to be broken in this tutorial, it holds the top shell down and you have to push it backwards to release the top shell.⏎
I struggled a bit because of it, so if you are too don't force it or you might break it too, just push the tab backwards, thx!
Reds Pc - 回复 分享
i hope person who designed scroll wheel on that mouse will die slow painful death from hiv
Tom Green - 回复 分享
@tomgreen55925 what's wrong with the scroll wheel on this mouse 😭
djancak - 回复 分享
@djancak the rubber wheel is easily collecting grease,dirt and other garbage then turn into a sticky,dirty mouse wheel.
I replaced it with an aftermarket aluminum alloy wheel, and it works much better (also lighter than stock one).
Soul Ryo - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 32
过去 7 天: 213
过去 30 天: 1,135
总计 21,035
