跳转到主内容
How to Install Ubuntu Linux
Thomas Sirack
Thomas Sirack4 其他贡献者
最后更新于 February 7, 2024
30分钟 - 1小时
中等
社区贡献指南
This guide is perfect for someone who is new to Ubuntu and would like to try it.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. How to Install Ubuntu Linux, Download Ubuntu: 步骤 1 中的图像 1,1
  2. How to Install Ubuntu Linux, Burn to Disk: 步骤 2 中的图像 1,2 How to Install Ubuntu Linux, Burn to Disk: 步骤 2 中的图像 2,2
    • Use disk burning software like ImgBurn to burn Ubuntu to a DVD, or you can use a USB flash drive instead. If you use a flash drive, download UNetbootin and create your installation media.
    • You do not need to burn Ubuntu to a disk if you are using a virtual machine.
  3. How to Install Ubuntu Linux, Boot to installation media: 步骤 3 中的图像 1,1
    • I recommend trying Ubuntu in a virtual machine, which is what I did.
    • If you are using a real computer, you may need to configure the BIOS or press a key on system startup. If you need to change the BIOS settings, set any Optical Drives or USB CD-ROM drives as the first boot priority.
    • If you want to use a virtual machine, set CD/DVD as the first boot priority and mount the iso file to the machine. There is plenty of virtualization software out there, like VirtualBox.
    • If you have successfully booted into the installation media, you will see this picture.
    • Click on the big "Install Ubuntu" button.
  4. How to Install Ubuntu Linux, Install Ubuntu: 步骤 4 中的图像 1,1
    • After a screen asking about additional software, you will asked what you would like to do with your hard disk.
    • If the installer refers to any sort of dual-booting, you must quit the installer and make unallocated space on your hard disk somehow. (See warning for info.)
    • If you are experienced with partitions, you may use this partition editor.
    • If you decide to use the partition editor, please be very careful. Partitions made with this partition editor can cause any other operating systems to become inaccessible.
结论
That's it! Now you can try Ubuntu all you want.
7等其他人完成本指南。
Thomas Sirack
于07/25/15注册
561 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 1,037
