跳转到主内容
How to Fix an Uneven Guitar Fret
Victoria
Victoria3 其他贡献者
最后更新于 June 5, 2024
30分钟
中等
This guide provides a straightforward 8-step procedure for rectifying an uneven guitar fret, a prevalent issue that can impact both the sound quality and ease of play on your instrument. Ideally, the metal frets on a guitar should exhibit uniform height; however, inconsistencies may arise due to varying levels of quality control during manufacturing, leading to undesirable buzzing noises when playing chords.
To address this problem, you will require a small flat metal file, sandpaper, fret guard or masking tape, paper towel, scissors, and a fret rocker or any flat edge. By diligently following the outlined steps in this manual, your guitar's fret should be restored to its original condition.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. How to Fix an Uneven Guitar Fret, How to Fix an Uneven Guitar Fret: 步骤 1 中的图像 1,2 How to Fix an Uneven Guitar Fret, How to Fix an Uneven Guitar Fret: 步骤 1 中的图像 2,2
    • Loosen the strings by turning each knob on the left of the guitar counter-clockwise.
    • Loosen until you can fit one finger underneath.
  2. How to Fix an Uneven Guitar Fret: 步骤 2 中的图像 1,1
    • Locate the general area where the strings are buzzing due to the uneven fret.
    • Place the long side of the fret rocker down over three frets.
    • Rock the fret rocker side to side.
    • If it moves, the fret in the middle of the three is higher than the others.
  3. How to Fix an Uneven Guitar Fret: 步骤 3 中的图像 1,1
    • Place the fret guard underneath the strings and over the uneven fret.
  4. How to Fix an Uneven Guitar Fret: 步骤 4 中的图像 1,3 How to Fix an Uneven Guitar Fret: 步骤 4 中的图像 2,3 How to Fix an Uneven Guitar Fret: 步骤 4 中的图像 3,3
    • Take one paper towel sheet and fold in half the long way.
    • Roll the paper towel tightly about halfway down the sheet.
    • Cut the paper towel as pictured.
    • Repeat once more, you should have two small paper towel rolls.
  5. How to Fix an Uneven Guitar Fret: 步骤 5 中的图像 1,1
    • Place the two rolls under the strings around the fret guard.
  6. How to Fix an Uneven Guitar Fret: 步骤 6 中的图像 1,2 How to Fix an Uneven Guitar Fret: 步骤 6 中的图像 2,2
    • File the top of the fret in an up down motion
    • Start slow, file back and forth only a couple times then see step 7
  7. How to Fix an Uneven Guitar Fret: 步骤 7 中的图像 1,1
    • Place the fret rocker over the frets again.
    • If it still rocks, repeat the previous step.
  8. How to Fix an Uneven Guitar Fret: 步骤 8 中的图像 1,3 How to Fix an Uneven Guitar Fret: 步骤 8 中的图像 2,3 How to Fix an Uneven Guitar Fret: 步骤 8 中的图像 3,3
    • Polish the top of the frets by sandpapering the top of the fret in an up/down motion.
    • Stop when fret feels smooth and looks shiny.
结论
Victoria
于04/25/24注册
157 声望
撰写一个指南
团队
UC Davis, Team 1-1, Whithaus Spring 2024 UC Davis, Team 1-1, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S1G1
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 142
