跳转到主内容
How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case
Abdul Haseeb Sajid
Abdul Haseeb Sajid 另一个贡献者
最后更新于 August 15, 2024
10 - 15 分钟
简单
If your COMFORTMATE FJYPD16H2 fan blade case is wobbling or moves when you pick the fan up, use this guide to repair it.
The blade case is the part around the fan blade and is there to protect you from the fast spinning blade.
Be careful of any broken parts as the edges of the plastic are sharp enough to cut skin.
You will need a piece of cloth or a paper towel to protect you when handling the fan blade in steps 4 and 10; safety gloves will also work.
你所需要的
  1. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case, How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 1 中的图像 1,1
    • Disconnect the fan from the power source.
  2. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 2 中的图像 1,1
    • Locate the locking mechanism.
  3. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 3 中的图像 1,2 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 3 中的图像 2,2
    • Pull the locking mechanism back and turn the front of the fan case counter clockwise and pull it off.
  4. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 4 中的图像 1,3 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 4 中的图像 2,3 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 4 中的图像 3,3
    • While holding the fan blade in place using a piece of cloth or a paper towel, remove the spinner by turning it clockwise.
    • The blades are sharp and can cause cuts.
  5. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 5 中的图像 1,2 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 5 中的图像 2,2
    • Pull the fan blade off and check for damage.
  6. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 6 中的图像 1,1
    • Remove the plastic nut on the back of the fan case by turning it counter clockwise and check for damage.
  7. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 7 中的图像 1,3 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 7 中的图像 2,3 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 7 中的图像 3,3
    • Make sure the holes on the back of the blade case are lined up with the protruding parts on the motorhead and is as far back as possible.
  8. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 8 中的图像 1,2 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 8 中的图像 2,2
    • While holding the blade case in place attach the plastic nut by turning it clockwise.
  9. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 9 中的图像 1,2 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 9 中的图像 2,2
    • Attach the fan blade back.
  10. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 10 中的图像 1,1
    • While holding the fan blade in place using a piece of cloth or a paper towel, attach the spinner by turning it counter clockwise.
  11. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 步骤 11 中的图像 1,1
    • Attach the front of the blade case.
终点
Abdul Haseeb Sajid
于07/04/24注册
193 声望
撰写一个指南
团队
York University, Team 1-23, O'Regan Summer 2024 York University, Team 1-23, O'Regan Summer 2024 的会员
YORK-O'REGAN-SU24S1G23
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 109
