跳转到主内容
How to Fix a Dent in a Hardside Suitcase
Samirah
Samirah3 其他贡献者
最后更新于 June 13, 2024
15 - 30 分钟
中等
Suitcases can be an expensive investment, so nothing is worse than when your suitcase is damaged and all you can worry about is the amount of money you’ll have to spend on a new one. This guide will help you remove the harsh dents from your suitcase, so you may use it again, without worrying about buying a new one. This guide uses items that are easily accessible such as a hairdryer and a screwdriver, so that you don’t have to spend any more money. Another benefit is that this guide can be completed quickly, so your suitcase can look better in no time.
Be cautious when using a hair dryer to heat your suitcase. Applying heat to one area for too long can melt the material and damage your luggage. When checking the heated area, use heat-resistant gloves to avoid burns. Additionally, remember that while this guide helps to remove the dent, the outcome may not restore the suitcase to its original appearance, especially if it has a textured hard case. As shown in this guide, the ridges around the previously dented area have smoothed out a bit.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. How to Fix a Dent in a Hardside Suitcase, How to Fix a Dent in a Hardside Suitcase: 步骤 1 中的图像 1,1
    • Before you begin, determine which tool is best to use for tapping out the dent, as this depends on the size of the dent. For this guide, the handle of a screwdriver was used, but a soft mallet would work well too.
  2. How to Fix a Dent in a Hardside Suitcase: 步骤 2 中的图像 1,1
    • Use the hair dryer on the dented area for a duration of 3 minutes.
    • Move the hair dryer around the dented area to avoid heat damage to your suitcase. Wear heat-resistant gloves and check the area periodically to ensure it is not overheating.
  3. How to Fix a Dent in a Hardside Suitcase: 步骤 3 中的图像 1,2 How to Fix a Dent in a Hardside Suitcase: 步骤 3 中的图像 2,2
    • Open the suitcase and use a screwdriver handle or soft mallet to tap out the dent about 3-5 times.
    • The screwdriver is being used to shape the dent back to its original shape towards the outside of the luggage.
  4. How to Fix a Dent in a Hardside Suitcase: 步骤 4 中的图像 1,1
    • Use a hair dryer to apply heat to the dented area for 1-3 minutes, moving the heat over the area in a circular motion.
    • This will soften the suitcase material so it's easier to tap out the dent.
  5. How to Fix a Dent in a Hardside Suitcase: 步骤 5 中的图像 1,1
    • Use a screwdriver handle or soft mallet to tap the dent back to the original shape or as close to it as possible. Hit the dent using your tool about 4-6 times.
  6. How to Fix a Dent in a Hardside Suitcase: 步骤 6 中的图像 1,1
    • The process is complete and the suitcase is back to its normal shape and can be used!
结论
Samirah
于02/02/24注册
138 声望
撰写一个指南
团队
York University, Team M-8, Allen Winter 2024 York University, Team M-8, Allen Winter 2024 的会员
YORK-ALLEN-W24SMG8
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 34
过去 30 天: 128
总计 1,355
