跳转到主内容
加入维修社区 - 创建账户
How to Change a Stretched Canvas
你所需要的
  1. How to Change a Stretched Canvas, How to Change a Stretched Canvas: 步骤 1 中的图像 1,2 How to Change a Stretched Canvas, How to Change a Stretched Canvas: 步骤 1 中的图像 2,2
    • Place the canvas upside down on a flat surface.
    询问修复机器人
    添加评论
  2. How to Change a Stretched Canvas: 步骤 2 中的图像 1,2 How to Change a Stretched Canvas: 步骤 2 中的图像 2,2
    • Place the picker tool under the staple
    • Begin to lift the staple off of the frame by moving the picker tool down towards the table.
    • Lift the staple halfway up (Do not completely remove yet).
    • Don't place your hands directly in front of pointy end of the picker tool.
    询问修复机器人
    添加评论
  3. How to Change a Stretched Canvas: 步骤 3 中的图像 1,2 How to Change a Stretched Canvas: 步骤 3 中的图像 2,2
    • Once the staple is halfway lifted, use the pliers to completely lift the staple from the frame.
    • Repeat steps 2-3 to remove the rest of staples.
    询问修复机器人
    添加评论
  4. How to Change a Stretched Canvas: 步骤 4 中的图像 1,1
    • Roll up your canvas for storage.
    • Roll the canvas with your painting on the outside to avoid cracking
    询问修复机器人
    添加评论
  5. How to Change a Stretched Canvas: 步骤 5 中的图像 1,3 How to Change a Stretched Canvas: 步骤 5 中的图像 2,3 How to Change a Stretched Canvas: 步骤 5 中的图像 3,3
    • Measure out the amount of canvas that is needed to cover the edges of the frame.
    • Once measured, make a small cut in the corner.
    • Use your hands to rip off the excess fabric.
    询问修复机器人
    添加评论
  6. How to Change a Stretched Canvas: 步骤 6 中的图像 1,2 How to Change a Stretched Canvas: 步骤 6 中的图像 2,2
    • Fold one side of the canvas fabric over the edge of one of the long sides of the frame.
    • While holding the canvas down, use the staple gun to place one staple in the middle
    询问修复机器人
    添加评论
  7. How to Change a Stretched Canvas: 步骤 7 中的图像 1,3 How to Change a Stretched Canvas: 步骤 7 中的图像 2,3 How to Change a Stretched Canvas: 步骤 7 中的图像 3,3
    • Go over to the other side of the frame and use the canvas pliers to grab the canvas fabric. To tighten canvas fabric, begin by holding the pliers at a 45 degree angle then moving the pliers down towards the table.
    • Place the canvas pliers where you intend to place a staple .
    • While holding the fabric down, place a staple in the middle of that side of the frame.
    • Continue Step 7 on the two short sides of the frame.
    询问修复机器人
    添加评论
  8. How to Change a Stretched Canvas: 步骤 8 中的图像 1,3 How to Change a Stretched Canvas: 步骤 8 中的图像 2,3 How to Change a Stretched Canvas: 步骤 8 中的图像 3,3
    • Choose one of the long sides of the frame and begin stapling from the center to about 3 inches away from the corner using the same canvas plier technique from step 7. Then repeat on other long side.
    • Next, repeat this stapling process on the two short sides
    询问修复机器人
    添加评论
  9. How to Change a Stretched Canvas: 步骤 9 中的图像 1,2 How to Change a Stretched Canvas: 步骤 9 中的图像 2,2
    • Trim the corner of the fabric to make folding easier.
    • The fabric that you cut away should be in the shape of a triangle.
    • Repeat on the other three corners.
    询问修复机器人
    添加评论
  10. How to Change a Stretched Canvas: 步骤 10 中的图像 1,3 How to Change a Stretched Canvas: 步骤 10 中的图像 2,3 How to Change a Stretched Canvas: 步骤 10 中的图像 3,3
    • Choose one corner of the frame and tuck excess fabric inside the fold.
    • Holding tightly onto the fabric, pull the fold up and over the the edge of the frame. Staple to secure both sides of the corner.
    询问修复机器人
    添加评论
  11. How to Change a Stretched Canvas: 步骤 11 中的图像 1,2 How to Change a Stretched Canvas: 步骤 11 中的图像 2,2
    • When you are finished, stretched canvas should be tight and it should sound like a drum when you tap on it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 86
总计 3,233
