跳转到主内容
How to Apply New Screen Adhesive in Your Google Pixel 8
你所需要的
  1. How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the old adhesive from the frame: 步骤 1 中的图像 1,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the old adhesive from the frame: 步骤 1 中的图像 2,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the old adhesive from the frame: 步骤 1 中的图像 3,3
    • In order for the new adhesive to properly seal, you must remove all the old adhesive and its residue.
    • Use the flat end of a spudger to scrape up and remove all the old adhesive from the frame.
    • If you're having trouble, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to the adhesive and scrape it up.
  2. How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the old adhesive residue: 步骤 2 中的图像 1,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the old adhesive residue: 步骤 2 中的图像 2,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the old adhesive residue: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • Once you've removed all the old adhesive, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to any residue left on the frame and wipe it away with a microfiber or lint-free cloth.
    • If you're having trouble, wrap the microfiber cloth around a spudger and use it to scrape the frame.
  3. How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the old adhesive from the screen: 步骤 3 中的图像 1,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the old adhesive from the screen: 步骤 3 中的图像 2,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the old adhesive from the screen: 步骤 3 中的图像 3,3
    • If you're installing a new screen, skip this step.
    • Repeat the cleaning procedure to remove all the old adhesive and its residue from the perimeter of the screen.
  4. How to Apply New Screen Adhesive in Your Google Pixel 8, Align the adhesive: 步骤 4 中的图像 1,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Align the adhesive: 步骤 4 中的图像 2,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Align the adhesive: 步骤 4 中的图像 3,3
    • Before applying the new adhesive, it's helpful to see how it will be oriented on your phone.
    • Hold the adhesive sheet so the clear liner is on the bottom and place it over your phone to find the proper alignment.
    • Use the cutouts for the spring contacts and the bottom speaker to help align the adhesive.
  5. How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the clear liner: 步骤 5 中的图像 1,1
    • Remove the larger clear liner from the back of the sheet to expose the adhesive.
  6. How to Apply New Screen Adhesive in Your Google Pixel 8, Place the adhesive: 步骤 6 中的图像 1,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Place the adhesive: 步骤 6 中的图像 2,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Place the adhesive: 步骤 6 中的图像 3,3
    • Be very careful during this step! Once the adhesive sticks to the frame you won't be able to reposition it. You'll have to start over with new adhesive if it gets applied incorrectly.
    • Gently place the top edge of the adhesive onto the frame. Use the frame's lip to help position the sheet.
    • Press down gently to secure the bottom corners and carefully lay the rest of the adhesive onto the frame.
  7. How to Apply New Screen Adhesive in Your Google Pixel 8, Secure the adhesive: 步骤 7 中的图像 1,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Secure the adhesive: 步骤 7 中的图像 2,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Secure the adhesive: 步骤 7 中的图像 3,3
    • The adhesive needs to be firmly secured to the frame before removing any liners to prevent it from pulling up and misaligning in the next step.
    • Be careful not to damage any spring contacts during this step.
    • Press down firmly and slide the flat end of a spudger around the entire perimeter of the frame to secure the adhesive.
  8. How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the larger blue liner: 步骤 8 中的图像 1,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the larger blue liner: 步骤 8 中的图像 2,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the larger blue liner: 步骤 8 中的图像 3,3
    • Use the pull tab at the top left corner of the adhesive to gently peel up and remove the larger blue liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  9. How to Apply New Screen Adhesive in Your Google Pixel 8, Reconnect the screen: 步骤 9 中的图像 1,2 How to Apply New Screen Adhesive in Your Google Pixel 8, Reconnect the screen: 步骤 9 中的图像 2,2
    • Reconnect the screen cable press connector.
    • Reinstall the screen cable cover.
  10. How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the inner liners: 步骤 10 中的图像 1,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the inner liners: 步骤 10 中的图像 2,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Remove the inner liners: 步骤 10 中的图像 3,3
    • The inner liner is removed in two separate strips.
    • Grip one of the pull tabs along the right edge of the adhesive and remove one half of the inner liner.
    • Repeat for the other half of the inner liner.
  11. How to Apply New Screen Adhesive in Your Google Pixel 8, Check the camera and cutouts: 步骤 11 中的图像 1,1
    • Before securing the screen, make sure the front facing camera is snug in its recess.
    • If you replaced the screen, check the front-facing camera hole and sensor cutout on the replacement screen and remove any remaining protective liners in it.
  12. How to Apply New Screen Adhesive in Your Google Pixel 8, Secure the screen: 步骤 12 中的图像 1,2 How to Apply New Screen Adhesive in Your Google Pixel 8, Secure the screen: 步骤 12 中的图像 2,2
    • Firmly press the screen into place on the frame.
    • You should feel the clips "pop" into place.
  13. How to Apply New Screen Adhesive in Your Google Pixel 8: 步骤 13 中的图像 1,2 How to Apply New Screen Adhesive in Your Google Pixel 8: 步骤 13 中的图像 2,2
    • Press firmly around the perimeter or the screen to secure it with the new adhesive.
  14. How to Apply New Screen Adhesive in Your Google Pixel 8, Strengthen the adhesive bond: 步骤 14 中的图像 1,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Strengthen the adhesive bond: 步骤 14 中的图像 2,3 How to Apply New Screen Adhesive in Your Google Pixel 8, Strengthen the adhesive bond: 步骤 14 中的图像 3,3
    • This step shows how to further strengthen the bond of your new screen adhesive.
    • In order to get even pressure around the perimeter of the screen, you'll need to account for the rear camera bump by placing objects on the rear cover.
    • If you have screen vice clamps, use them to work around the camera bar.
    • Lay your phone screen side down on a clean, flat surface.
    • Put tape around the perimeter of your phone to protect the rear cover.
    • Place coins or similarly thick objects around the perimeter of the back cover. Make sure they're as thick or thicker than the camera bump.
    • Place heavy objects such as books on your phone and leave them for 30 minutes or longer. Ideally, leave them stacked overnight.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 8 Answers Community for help.
2等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
213,838 声望
创作了1,041篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,738篇指南
1指南评论
People, don't forget to remove the old glue on the frame's edges. I initially didn't cause Ifixit doesn't mention it, but it was a mistake as it prevent the new screen to really clip in and seal properly. I now need to buy a special glue and glue the screen neatly again to make sure it is waterproof.
Louise - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 55
过去 30 天: 234
总计 5,099
