跳转到主内容
How to Apply Back Cover Adhesive in Your Google Pixel 8a
你所需要的
  1. How to Apply Back Cover Adhesive in Your Google Pixel 8a, Remove the old back cover adhesive: 步骤 1 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a, Remove the old back cover adhesive: 步骤 1 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a, Remove the old back cover adhesive: 步骤 1 中的图像 3,3
    • Use a spudger and tweezers to scrape up and remove all the old back cover adhesive from the entire perimeter of the frame.
  2. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 2 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 2 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 2 中的图像 3,3
    • Use a spudger and tweezers to scrape up and remove any adhesive from above and below the rear cameras.
    • If necessary, soften the adhesive with a hair dryer or heated iOpener.
  3. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 3 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 3 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 3 中的图像 3,3
    • If you're reusing your back cover, repeat the previous two steps to remove all the old adhesive from the cover.
    • Be careful not to touch the lens covers on your back cover. If they're dirty, wipe them with a clean microfiber cloth.
  4. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 4 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 4 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 4 中的图像 3,3
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the perimeter of the frame and the area where the two smaller adhesive strips were.
    • Wipe any adhesive residue away using a microfiber or lint-free cloth.
    • If you're reusing your back cover, use the same process to clean up any adhesive residue.
  5. How to Apply Back Cover Adhesive in Your Google Pixel 8a, Apply new adhesives: 步骤 5 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a, Apply new adhesives: 步骤 5 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a, Apply new adhesives: 步骤 5 中的图像 3,3
    • If you have a new back cover, your part may come with lower and top back cover adhesive pre-installed. If this is the case, you can skip down two steps to apply the perimeter adhesive.
    • Remove the shorter, wider strip of back cover adhesive from its liner and place it on the plastic housing just above the rear cameras.
  6. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 6 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 6 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 6 中的图像 3,3
    • Remove the longer, thinner piece of back cover adhesive from its liner and place it on the logic board cover just below the rear cameras.
  7. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 7 中的图像 1,2 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 7 中的图像 2,2
    • Before removing any liners from the back cover adhesive, hold it over the frame and use the cutouts to make sure it's oriented correctly.
    • The blue liner should be facing up, with the larger, clear liner on the bottom.
  8. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 8 中的图像 1,1
    • Peel down the top half of the larger liner to expose the adhesive—don't remove the whole liner yet.
  9. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 9 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 9 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 9 中的图像 3,3
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
    • Keep the larger liner folded towards the bottom of the phone during this step.
    • Lay the exposed top edge of the adhesive onto the frame, using the frame's lip to help align it.
    • Once the top edge is properly aligned, gently press down with your fingers to secure it in place.
  10. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 10 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 10 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 10 中的图像 3,3
    • Slowly lay the rest of the adhesive onto the frame, peeling away the large liner as you go.
  11. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 11 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 11 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 11 中的图像 3,3
    • Use the flat end of your spudger to press along the perimeter of the adhesive and secure it to the frame.
  12. How to Apply Back Cover Adhesive in Your Google Pixel 8a, Remove the liners: 步骤 12 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a, Remove the liners: 步骤 12 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a, Remove the liners: 步骤 12 中的图像 3,3
    • Slowly peel and remove the blue liner.
    • If the adhesive starts to peel up with the liner, check that you’ve pushed all of it into place with your spudger. If it continues to peel up, hold it down with the point of your spudger as you go.
  13. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 13 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 13 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 13 中的图像 3,3
    • Peel and remove the liners from the two smaller strips of adhesive near the rear cameras.
  14. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 14 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 14 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 14 中的图像 3,3
    • Grab the pull tab on the top edge and slowly peel and remove the remaining liner.
  15. How to Apply Back Cover Adhesive in Your Google Pixel 8a, Secure the back cover: 步骤 15 中的图像 1,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a, Secure the back cover: 步骤 15 中的图像 2,3 How to Apply Back Cover Adhesive in Your Google Pixel 8a, Secure the back cover: 步骤 15 中的图像 3,3
    • Align the back cover over the frame and press it into place.
    • Firmly press around the perimeter of the back cover to secure it.
    • To further strengthen the adhesive bond, lightly heat the back cover's perimeter with a hair dryer or heated iOpener and continue pressing it into place.
  16. How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 16 中的图像 1,2 How to Apply Back Cover Adhesive in Your Google Pixel 8a: 步骤 16 中的图像 2,2
    • Firmly press down on the back cover above and below the camera bump to secure the cover with the two smaller strips of adhesive.
结论
4等其他人完成本指南。
Spencer Day
于09/14/22注册
154,757 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 83
总计 1,227
