跳转到主内容
加入维修社区 - 创建账户
Hover-1 Charger Gyroscope Sensor Board Replacement
你所需要的
    1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: 步骤 1 中的图像 1,2 Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: 步骤 1 中的图像 2,2
      • Flip the hoverboard over so that the warning label is facing up.
      • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
      • Remove the four 10 mm screws with a Phillips #2 screwdriver.
      • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
      添加评论
    2. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 2 中的图像 1,1
      • Pull the right cover away from the hoverboard to expose the battery.
      询问修复机器人
      添加评论
    3. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 3 中的图像 1,2 Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 3 中的图像 2,2
      • Disconnect the two pronged black and yellow cable.
      询问修复机器人
      添加评论
    4. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 4 中的图像 1,1
      • Pull the left cover away from the hoverboard.
      询问修复机器人
      添加评论
    5. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 5 中的图像 1,2 Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 5 中的图像 2,2
      • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
      询问修复机器人
      添加评论
    1. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 步骤 6 中的图像 1,3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 步骤 6 中的图像 2,3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 步骤 6 中的图像 3,3
      • Unplug the white five pin connector from the gyroscope sensor board.
      • Unplug the red, yellow, blue, green, black and white six pin connector.
      • Unplug the black and red two pin connector.
      • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
      询问修复机器人
      添加评论
    2. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 7 中的图像 1,2 Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 7 中的图像 2,2
      • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
      询问修复机器人
      添加评论
    3. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 8 中的图像 1,3 Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 8 中的图像 2,3 Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 8 中的图像 3,3
      • Push the rubber sheaths away from the clasp of the green bullet connector.
      • Grasp the connector at the metal junction and disconnect.
      • Repeat for the yellow and red bullet connectors.
      • There may be a zip tie holding these wires together. Cut this off.
      • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
      添加评论
    4. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 9 中的图像 1,1
      • Remove the gyroscope sensor board.
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G1
4 名成员
创作了6篇指南
5指南评论
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - 回复 分享
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - 回复 分享
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - 回复 分享
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - 回复 分享
this is a joke. 2 years still not one kind enough soul to help find where to purchase replacements!!!!!!!!
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 6,108
