跳转到主内容
加入维修社区 - 创建账户
Hover-1 Charger Battery Replacement
你所需要的
    1. Hover-1 Charger Battery Replacement, Battery: 步骤 1 中的图像 1,2 Hover-1 Charger Battery Replacement, Battery: 步骤 1 中的图像 2,2
      • Flip the hoverboard over so that the warning label is facing up.
      • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
      • Remove the four 10 mm screws with a Phillips #2 screwdriver.
      • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
      添加评论
    2. Hover-1 Charger Battery Replacement: 步骤 2 中的图像 1,1
      • Pull the right cover away from the hoverboard to expose the battery.
      询问修复机器人
      添加评论
    3. Hover-1 Charger Battery Replacement: 步骤 3 中的图像 1,2 Hover-1 Charger Battery Replacement: 步骤 3 中的图像 2,2
      • Unplug the battery by disconnecting the two pronged black and yellow cable.
      询问修复机器人
      添加评论
    4. Hover-1 Charger Battery Replacement: 步骤 4 中的图像 1,1
      • Pull the left cover away from the hoverboard.
      添加评论
    5. Hover-1 Charger Battery Replacement: 步骤 5 中的图像 1,2 Hover-1 Charger Battery Replacement: 步骤 5 中的图像 2,2
      • Disconnect the two pronged black and yellow cable.
      • Thread the cable through the middle cylinder of the hoverboard.
      询问修复机器人
      添加评论
    6. Hover-1 Charger Battery Replacement: 步骤 6 中的图像 1,2 Hover-1 Charger Battery Replacement: 步骤 6 中的图像 2,2
      • Unscrew the four 10mm screws that are holding the battery casing in place. Use a Phillips #2 screwdriver.
      • If there is a zip-tie connecting the wires together, carefully cut it with a wire cutters.
      询问修复机器人
      添加评论
    7. Hover-1 Charger Battery Replacement: 步骤 7 中的图像 1,3 Hover-1 Charger Battery Replacement: 步骤 7 中的图像 2,3 Hover-1 Charger Battery Replacement: 步骤 7 中的图像 3,3
      • On the battery side, unplug the white five pin connector on the circuitboard.
      • Unplug the black, yellow, green and red connector on the circuitboard.
      询问修复机器人
      添加评论
    8. Hover-1 Charger Battery Replacement: 步骤 8 中的图像 1,1
      • Move all the loose cables to the side. Pull the battery casing away from the battery.
      询问修复机器人
      添加评论
    9. Hover-1 Charger Battery Replacement: 步骤 9 中的图像 1,1
      • Use the opening tool to remove the battery from the metal casing.
      • The battery is stuck to the metal casing with strong adhesive; do not be afraid to apply a strong force with the opening tool.
      询问修复机器人
      添加评论
    10. Hover-1 Charger Battery Replacement: 步骤 10 中的图像 1,1
      • Remove the battery.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G1
4 名成员
创作了6篇指南
1指南评论
Can I replace my battery 25.2v to a 36v.
Airie Green - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 75
总计 10,572
