跳转到主内容
加入维修社区 - 创建账户
Heyday Suitcase Turntable Volume Knob Replacement
你所需要的
    1. Heyday Suitcase Turntable Volume Knob Replacement, Baseboard: 步骤 1 中的图像 1,1
      • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
      询问修复机器人
      添加评论
    2. Heyday Suitcase Turntable Volume Knob Replacement: 步骤 2 中的图像 1,1
      • Use a metal spudger to pry the baseboard off of the case.
      • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
      询问修复机器人
      添加评论
    3. Heyday Suitcase Turntable Volume Knob Replacement: 步骤 3 中的图像 1,2 Heyday Suitcase Turntable Volume Knob Replacement: 步骤 3 中的图像 2,2
      • Disconnect the cords from the circuit board.
      • Take a picture beforehand so it's easier to put them back during reassembly.
      • Remove the baseboard.
      询问修复机器人
      添加评论
    1. Heyday Suitcase Turntable Volume Knob Replacement, Volume Knob: 步骤 4 中的图像 1,1
      • Use a metal spudger to pry the volume knob off of the baseboard.
      询问修复机器人
      添加评论
    2. Heyday Suitcase Turntable Volume Knob Replacement: 步骤 5 中的图像 1,2 Heyday Suitcase Turntable Volume Knob Replacement: 步骤 5 中的图像 2,2
      • Use your fingers to unscrew the nut securing the volume knob.
      询问修复机器人
      添加评论
    3. Heyday Suitcase Turntable Volume Knob Replacement: 步骤 6 中的图像 1,1
      • Use a metal spudger to pry the power knob off of the baseboard.
      询问修复机器人
      添加评论
    4. Heyday Suitcase Turntable Volume Knob Replacement: 步骤 7 中的图像 1,2 Heyday Suitcase Turntable Volume Knob Replacement: 步骤 7 中的图像 2,2
      • Use your fingers to unscrew the nut securing the power knob.
      询问修复机器人
      添加评论
    5. Heyday Suitcase Turntable Volume Knob Replacement: 步骤 8 中的图像 1,1
      • Pull the circuit board down from the baseboard to separate them.
      询问修复机器人
      添加评论
    6. Heyday Suitcase Turntable Volume Knob Replacement: 步骤 9 中的图像 1,1
      • To release the volume knob, desolder each of the eight solder joints.
      • Make sure to take proper safety precautions while operating soldering iron. For a review, take a look at the guide on How to Solder and Desolder Connections.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 2-1, Petersen Fall 2022 UMass Dartmouth, Team 2-1, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S2G1
4 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 423
