跳转到主内容
加入维修社区 - 创建账户
Headphone Plug Replacement
你所需要的
    1. Headphone Plug Replacement, Audio Jack: 步骤 1 中的图像 1,2 Headphone Plug Replacement, Audio Jack: 步骤 1 中的图像 2,2
      • Unscrew the casing from your replacement plug.
      询问修复机器人
      添加评论
    2. Headphone Plug Replacement: 步骤 2 中的图像 1,3 Headphone Plug Replacement: 步骤 2 中的图像 2,3 Headphone Plug Replacement: 步骤 2 中的图像 3,3
      在这个步骤中使用的工具:
      Digital Multimeter
      $59.95
      • Using a multimeter (set in ohms to test resistance), test each terminal on the base of the plug to see which terminal corresponds to which speaker (left or right). You'll know they correspond when a value other than 1 appears on the multimeter.
      • Image 3 shows which part of the plug corresponds to each cable:
      • Left
      • Right
      • Common (or ground)
      • My results showed that the terminal with the larger hole corresponded to the right speaker, while the terminal with the smaller hole corresponded to the left speaker. Your results may differ.
      询问修复机器人
      添加评论
    3. Headphone Plug Replacement: 步骤 3 中的图像 1,2 Headphone Plug Replacement: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      Flush Cutter
      $34.95
      • Using your wire cutter, remove the broken 3.5mm plug from the wire.
      询问修复机器人
      添加评论
    4. Headphone Plug Replacement: 步骤 4 中的图像 1,3 Headphone Plug Replacement: 步骤 4 中的图像 2,3 Headphone Plug Replacement: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      Wire Stripper
      $34.95
      • Use your wire stripper to expose about 2cm of the the wire.
      • You must also remove the coating from each smaller, individual wire by using a wire stripper, fine sandpaper, or something of that sort.
      • If you attempt to solder the wires without removing the coating, the connection most likely will not work.
      询问修复机器人
      添加评论
    5. Headphone Plug Replacement: 步骤 5 中的图像 1,2 Headphone Plug Replacement: 步骤 5 中的图像 2,2
      • Slide the casing (from Step 1) onto the wire.
      • You'll have to screw this back onto the plug at the end, so be sure it's facing the correct way.
      询问修复机器人
      添加评论
    6. Headphone Plug Replacement: 步骤 6 中的图像 1,3 Headphone Plug Replacement: 步骤 6 中的图像 2,3 Headphone Plug Replacement: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      Helping Hands
      $9.99
      • Helping hands may be helpful when soldering. If you have never soldered before, check out this soldering technique guide.
      • Slide the red wire through the hole of the terminal that corresponds to the right speaker. Wrap the wire around the terminal a few times, then solder it in place.
      • Repeat this step for the terminal that corresponds to the left speaker. Note that the left audio wire is often white or green.
      • Finally, solder the common/ground wire (often copper colored) and any multicolored wires through the remaining hole.
      • The pictures show a blue wire and several yellow wires. The blue wire was soldered with the ground wire, and the yellow wires turned out simply to be nylon (not actual wires).
      添加评论
    7. Headphone Plug Replacement: 步骤 7 中的图像 1,1
      • To finish, screw the casing back onto the plug.
      • Be sure the two terminals (or connecting wires) do not touch each other; if they touch, the fix will not work properly.
      询问修复机器人
      添加评论
结论
If the fix did not work, make sure the wires are in direct contact with the terminals. Also make sure that they are not in contact with each other. If done correctly, your trusty pair of earphones (or headphones) can be trusted for quite a while longer!
取消:我没有完成这个指南。
27等其他人完成本指南。
Andrew Yoder
于04/09/15注册
1,141 声望
撰写一个指南
团队
Cal Poly, Team 28-4, Green Spring 2015 Cal Poly, Team 28-4, Green Spring 2015 的会员
CPSU-GREEN-S15S28G4
6 名成员
创作了25篇指南
2指南评论
The first sentence in your introduction can maybe be changed to: "Often times one earpiece of the earphones stop working."
Your description is well-written and thoroughly describes the process. I would just add pictures specifically pointing to the different parts you mention in your steps.
Otherwise it's all good! :)
Salonee - 回复 分享
Is there a special fix for earphones with a control unit embedded?
Marcel Alani - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 55
过去 30 天: 258
总计 63,242
