跳转到主内容
加入维修社区 - 创建账户
Hair Dryer Heating Element Replacement
你所需要的
    1. Hair Dryer Heating Element Replacement, Nozzle: 步骤 1 中的图像 1,2 Hair Dryer Heating Element Replacement, Nozzle: 步骤 1 中的图像 2,2
      • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
      • If nozzle is not attached, skip to next step.
      询问修复机器人
      添加评论
    1. Hair Dryer Heating Element Replacement, Grating: 步骤 2 中的图像 1,1
      • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
      • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. Hair Dryer Heating Element Replacement: 步骤 3 中的图像 1,1
      • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
      询问修复机器人
      添加评论
    3. Hair Dryer Heating Element Replacement: 步骤 4 中的图像 1,1
      • Separate the hair dryer grating into the three pieces seen in the image.
      询问修复机器人
      添加评论
    1. Hair Dryer Heating Element Replacement, Heating Element: 步骤 5 中的图像 1,1
      • Using the Phillips #1 screwdriver remove the two screws holding the handle of the dryer together.
      询问修复机器人
      添加评论
    2. Hair Dryer Heating Element Replacement: 步骤 6 中的图像 1,2 Hair Dryer Heating Element Replacement: 步骤 6 中的图像 2,2
      • Carefully separate the plastic casing using a spudger. Your hairdryer should now be disassembled into two large halves.
      • This can also be done with your hands if you twist the sides of the hair dryer slightly in opposite directions.
      询问修复机器人
      添加评论
    3. Hair Dryer Heating Element Replacement: 步骤 7 中的图像 1,1
      • Remove the heat-element housing by sliding it off of the dryer in the direction away from the handle.
      • Make sure the heating element is facing up so that removal is easier. If there is a casing, slightly twist as needed.
      询问修复机器人
      添加评论
    4. Hair Dryer Heating Element Replacement: 步骤 8 中的图像 1,1
      • Isolate the heating element.
      • Use a desoldering wick and soldering iron to desolder the wires.
      • Refer to this soldering page for more information on soldering.
      • You will need to be careful with these wires. Do not cut or yank the wires; this may cause further issues with your hair dryer.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Make sure wiring is enclosed in the body of the hair dryer, and the heating element casing is attached properly before screwing it closed.
取消:我没有完成这个指南。
9等其他人完成本指南。
Mitch
于10/04/12注册
37 声望
创作了5篇指南
团队
Cal Poly, Team 24-29, Regan Fall 2012 Cal Poly, Team 24-29, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G29
5 名成员
创作了70篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 40
过去 30 天: 148
总计 47,641
