跳转到主内容
HUAWEI HONOR 5X Battery Replacement
Klara Asllani
Klara Asllani3 其他贡献者
最后更新于 September 3, 2021
15 - 30 分钟
中等
The battery should be inspected if the phone is constantly overheating and powering off.
你所需要的
工具
查看更多...
  1. HUAWEI HONOR 5X Battery Replacement, HUAWEI HONOR 5X Disassembly: 步骤 1 中的图像 1,1
    • Turn off your cell phone before disassembling.
  2. HUAWEI HONOR 5X Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. HUAWEI HONOR 5X Battery Replacement: 步骤 3 中的图像 1,2 HUAWEI HONOR 5X Battery Replacement: 步骤 3 中的图像 2,2
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. HUAWEI HONOR 5X Battery Replacement: 步骤 4 中的图像 1,1
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. HUAWEI HONOR 5X Battery Replacement: 步骤 5 中的图像 1,2 HUAWEI HONOR 5X Battery Replacement: 步骤 5 中的图像 2,2
    • Pry off the back with a plastic opening tool.
  6. HUAWEI HONOR 5X Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Remove the pink sticker.
    What is this pink sticker called so I can purchase a replacement? Can copper foil, conducive tape be used in place of the clear pink sticker? I would appreate answers to both questions please. Thank you.
    RJEFFRIES - 回复
  7. HUAWEI HONOR 5X Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the three 1.5mm Phillips #000 screws.
  8. HUAWEI HONOR 5X Battery Replacement: 步骤 8 中的图像 1,2 HUAWEI HONOR 5X Battery Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to disconnect the orange and black battery cables from the motherboard.
  9. HUAWEI HONOR 5X Battery Replacement: 步骤 9 中的图像 1,1
    • Remove the battery from the phone.
结论
7等其他人完成本指南。
Klara Asllani
于01/25/18注册
788 声望
创作了5篇指南
团队
USF Tampa, Team S7-G6, Passmore Spring 2018 USF Tampa, Team S7-G6, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G6
3 名成员
创作了12篇指南
4指南评论
Just did this successfully, thanks for the steps.
I’d suggest adding to BE CAREFUL WHEN PRYING OUT THE BATTERY. #1 there is the screen cable under there and if you damage that, then have fun getting a new screen. #2 lithium batteries can ignite when punctured (like I did). Go easy working your way in and take note of where the screen cable is (lower black cable in step 9 image).
russellvinegar - 回复
11/09/19 - What is this pink sticker called so I can purchase a replacement? Can copper foil, conducive tape be used in place of the clear pink sticker? I would appreciate answers to both questions please. Thank you.
RJEFFRIES - 回复
Anyone know where I can get replacement 1.17mm Torx T3 screws? Mine came stripped. I had a tough time getting them out and don’t want to use the same ones to put back in.
Melissa Padilla - 回复
I have an Honor 5x, model KIW-L24. It has T2 torx screws, not T3, at the bottom, and I am totally unable to open it after removing the screws and the two SIM trays, Is mine somehow different?
Bob Brown - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 57
总计 6,046
