跳转到主内容
加入维修社区 - 创建账户
HTC Trophy Power Button Replacement
你所需要的
    1. HTC Trophy Power Button Replacement, Battery: 步骤 1 中的图像 1,3 HTC Trophy Power Button Replacement, Battery: 步骤 1 中的图像 2,3 HTC Trophy Power Button Replacement, Battery: 步骤 1 中的图像 3,3
      • Power off the phone before starting.
      • Remove the back panel by inserting the IFixIt opening tool into gap at the top of the rear and prying upward.
      询问修复机器人
      添加评论
    2. HTC Trophy Power Button Replacement: 步骤 2 中的图像 1,3 HTC Trophy Power Button Replacement: 步骤 2 中的图像 2,3 HTC Trophy Power Button Replacement: 步骤 2 中的图像 3,3
      • Remove the battery by inserting the IFixIt opening tool into the small gap between the battery and the surrounding plastic.
      • Apply a small force towards the bottom of the phone and lift upwards.
      • Be careful not to puncture the battery.
      询问修复机器人
      添加评论
    1. HTC Trophy Power Button Replacement, Display Assembly: 步骤 3 中的图像 1,3 HTC Trophy Power Button Replacement, Display Assembly: 步骤 3 中的图像 2,3 HTC Trophy Power Button Replacement, Display Assembly: 步骤 3 中的图像 3,3
      • Remove the 5 screws holding the two phone halves together.
      • Three 4mm long T5 Torx screws.
      • Press a T5 Torx screwdriver into the void sticker and remove the 4mm long T5 Torx screw.
      • One 4mm long Philips #000 screw.
      • Remove the installed SIM card if one is present.
      询问修复机器人
      添加评论
    2. HTC Trophy Power Button Replacement: 步骤 4 中的图像 1,3 HTC Trophy Power Button Replacement: 步骤 4 中的图像 2,3 HTC Trophy Power Button Replacement: 步骤 4 中的图像 3,3
      • Insert the IFixIt opening tool into the seem of the plastic around the edge of the phone and pry the two halves apart.
      • There are small plastic clips holding the phone together. Slide the opening tool around the edge until it clicks apart to avoid damage.
      • The volume button will fall out when the phone is opened.
      • The black sticker beneath the battery will rip once the phone is separated.
      询问修复机器人
      添加评论
    3. HTC Trophy Power Button Replacement: 步骤 5 中的图像 1,3 HTC Trophy Power Button Replacement: 步骤 5 中的图像 2,3 HTC Trophy Power Button Replacement: 步骤 5 中的图像 3,3
      • Remove the three screws holding the mother board to the display assembly.
      • One 2mm long Philips #000 screw.
      • Two 4mm long T5 Torx screws in the holes of the plastic.
      询问修复机器人
      添加评论
    4. HTC Trophy Power Button Replacement: 步骤 6 中的图像 1,3 HTC Trophy Power Button Replacement: 步骤 6 中的图像 2,3 HTC Trophy Power Button Replacement: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      • Remove the black tape cover the ribbon cable connectors with tweezers.
      • Disconnect the ribbon cables from the connectors.
      • Ribbon cables are extremely fragile.
      询问修复机器人
      添加评论
    5. HTC Trophy Power Button Replacement: 步骤 7 中的图像 1,2 HTC Trophy Power Button Replacement: 步骤 7 中的图像 2,2
      • Remove power button from the top of the phone with tweezers.
      询问修复机器人
      添加评论
    6. HTC Trophy Power Button Replacement: 步骤 8 中的图像 1,3 HTC Trophy Power Button Replacement: 步骤 8 中的图像 2,3 HTC Trophy Power Button Replacement: 步骤 8 中的图像 3,3
      • Use the iFixit opening tool to separate the motherboard from the display assembly.
      询问修复机器人
      添加评论
    1. HTC Trophy Power Button Replacement, Motherboard: 步骤 9 中的图像 1,3 HTC Trophy Power Button Replacement, Motherboard: 步骤 9 中的图像 2,3 HTC Trophy Power Button Replacement, Motherboard: 步骤 9 中的图像 3,3
      • Remove the plastic piece off of the motherboard.
      • Put pressure outwards to release these clips with the iFixit opening tool and you fingers.
      询问修复机器人
      添加评论
    1. HTC Trophy Power Button Replacement, Power Button: 步骤 10 中的图像 1,2 HTC Trophy Power Button Replacement, Power Button: 步骤 10 中的图像 2,2
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 364
