跳转到主内容
加入维修社区 - 创建账户
HTC One Front Panel Replacement
你所需要的
  1. HTC One Front Panel Replacement, Front Panel: 步骤 1 中的图像 1,2 HTC One Front Panel Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Use the plastic opening tool to scrape and loosen the adhesive from the crease surrounding the screen.
    • A good place to start is the volume button and it should come right out as you pry.
    询问修复机器人
    添加评论
  2. HTC One Front Panel Replacement: 步骤 2 中的图像 1,1
    • Wedge the plastic opening tool into the crack around the screen on the top, left and right sides.
    • This step can be sped up by using a heat gun or iOpener to heat up the glue.
    询问修复机器人
    添加评论
  3. HTC One Front Panel Replacement: 步骤 3 中的图像 1,2 HTC One Front Panel Replacement: 步骤 3 中的图像 2,2
    • Once the screen has been loosened on the top, left and right edges, lift the screen.
    • The screen will stay on a hinge until the final step.
    询问修复机器人
    添加评论
  4. HTC One Front Panel Replacement: 步骤 4 中的图像 1,1
    • Gently remove the volume button. Using the plastic opening tool, loosen the back panel of the phone. Begin in the space where the battery was and work around the phone, following the crease of the back panel.
    询问修复机器人
    添加评论
  5. HTC One Front Panel Replacement: 步骤 5 中的图像 1,2 HTC One Front Panel Replacement: 步骤 5 中的图像 2,2
    • Pry the back open once loose and lift. The back panel will come off with time.
    询问修复机器人
    添加评论
  6. HTC One Front Panel Replacement: 步骤 6 中的图像 1,3 HTC One Front Panel Replacement: 步骤 6 中的图像 2,3 HTC One Front Panel Replacement: 步骤 6 中的图像 3,3
    • Remove all the #000 screws with a #000 Phillips screw driver
    • Some screws are hidden by tape so remove the tape and check for screws.
    询问修复机器人
    添加评论
  7. HTC One Front Panel Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tweezers to get underneath the mother board to lift.
    • Lift slowly because it is not fully disconnected yet.
    询问修复机器人
    添加评论
  8. HTC One Front Panel Replacement: 步骤 8 中的图像 1,2 HTC One Front Panel Replacement: 步骤 8 中的图像 2,2
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it).
    • Lift the camera out of the motherboard.
    询问修复机器人
    添加评论
  9. HTC One Front Panel Replacement: 步骤 9 中的图像 1,2 HTC One Front Panel Replacement: 步骤 9 中的图像 2,2
    • Lift the motherboard completely out of the phone. (may stay attached at the bottom by tape)
    询问修复机器人
    添加评论
  10. HTC One Front Panel Replacement: 步骤 10 中的图像 1,2 HTC One Front Panel Replacement: 步骤 10 中的图像 2,2
    • Use the blue opening tool to pry up the battery from the frame.
    • The battery is glued to the frame so you will have to put force.
    • Do not break the battery upon removal.
    询问修复机器人
    添加评论
  11. HTC One Front Panel Replacement: 步骤 11 中的图像 1,3 HTC One Front Panel Replacement: 步骤 11 中的图像 2,3 HTC One Front Panel Replacement: 步骤 11 中的图像 3,3
    • Remove the motherboard entirely if not done on step 9.
    询问修复机器人
    添加评论
  12. HTC One Front Panel Replacement: 步骤 12 中的图像 1,2 HTC One Front Panel Replacement: 步骤 12 中的图像 2,2
    • Remove the screws in the speaker at the bottom of the frame.
    • Lift the speaker out of the frame.
    询问修复机器人
    添加评论
  13. HTC One Front Panel Replacement: 步骤 13 中的图像 1,1
    • Lift the screen out of its hinge.
    • Replace the screen.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
17等其他人完成本指南。
Jeremy
于09/23/14注册
1,862 声望
创作了2篇指南
团队
USF Tampa, Team 12-1, Blackwell Fall 2014 USF Tampa, Team 12-1, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S12G1
4 名成员
创作了12篇指南
1指南评论
Thanks for the tutorial. Not the most repair friendly device,! It took me 2,5 hours, so it's surely possible to do it faster than 10 hours ;)
Albert Zweistein - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 39
总计 18,866
