简介
Is the screen on your laptop malfunctioning? Here are some possible problems with your screen. If you determine that the screen needs to be replaced, follow this replacement guide!
你所需要的
Flip the laptop over.
Slide the lever with the battery symbol beside it firmly until the battery pops out.
Remove the battery from the laptop.
在这个步骤中使用的工具:Tweezers$4.99
Orient the laptop keyboard-side up.
Use tweezers to remove the adhesive covers for the screws.
9等其他人完成本指南。
3指南评论
Worked great! Only caution that I would add is that on one of the machines I took apart, the adhesive strip behind the bottom of the bezel stuck to the bezel and not the circuit board behind. I had to carefully slide my finger between the adhesive strip and the bezel to separate them. Once the bezel was removed, I was able to stick the adhesive back down. I think this laptop may have been exposed to some sort of liquid, so this may not be a common issue.
dwakefield - 回复 分享
Hello can i replace my hd screen with another fhd one?
