跳转到主内容
加入维修社区 - 创建账户
HP Stream 7 Motherboard Replacement
你所需要的
    1. HP Stream 7  Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 HP Stream 7  Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      询问修复机器人
      添加评论
    2. HP Stream 7  Motherboard Replacement: 步骤 2 中的图像 1,2 HP Stream 7  Motherboard Replacement: 步骤 2 中的图像 2,2
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      询问修复机器人
      添加评论
    3. HP Stream 7  Motherboard Replacement: 步骤 3 中的图像 1,2 HP Stream 7  Motherboard Replacement: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      添加评论
    1. HP Stream 7  Motherboard Replacement, Motherboard Replacement: 步骤 4 中的图像 1,1
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      询问修复机器人
      添加评论
    2. HP Stream 7  Motherboard Replacement: 步骤 5 中的图像 1,2 HP Stream 7  Motherboard Replacement: 步骤 5 中的图像 2,2
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      询问修复机器人
      添加评论
    3. HP Stream 7  Motherboard Replacement: 步骤 6 中的图像 1,2 HP Stream 7  Motherboard Replacement: 步骤 6 中的图像 2,2
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 18-5, Forte Fall 2016 Cal Poly, Team 18-5, Forte Fall 2016 的会员
CPSU-FORTE-F16S18G5
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 43
总计 2,108
