跳转到主内容
HP Stream 13-c110nr Speakers Replacement
Stacey Deel
Stacey Deel3 其他贡献者
最后更新于 May 7, 2019
20分钟
中等
The Speaker assembly guide will assist the user in removal of the speaker assembly from the HP Stream 13-c110nr.
你所需要的
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. HP Stream 13-c110nr Speakers Replacement, Keyboard Assembly: 步骤 1 中的图像 1,1
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Speakers Replacement: 步骤 2 中的图像 1,1
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Speakers Replacement: 步骤 3 中的图像 1,3 HP Stream 13-c110nr Speakers Replacement: 步骤 3 中的图像 2,3 HP Stream 13-c110nr Speakers Replacement: 步骤 3 中的图像 3,3
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Speakers Replacement: 步骤 4 中的图像 1,3 HP Stream 13-c110nr Speakers Replacement: 步骤 4 中的图像 2,3 HP Stream 13-c110nr Speakers Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Speakers Replacement: 步骤 5 中的图像 1,1
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Speakers Replacement: 步骤 6 中的图像 1,3 HP Stream 13-c110nr Speakers Replacement: 步骤 6 中的图像 2,3 HP Stream 13-c110nr Speakers Replacement: 步骤 6 中的图像 3,3
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Speakers Replacement: 步骤 7 中的图像 1,1
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Speakers Replacement: 步骤 8 中的图像 1,2 HP Stream 13-c110nr Speakers Replacement: 步骤 8 中的图像 2,2
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Speakers Replacement: 步骤 9 中的图像 1,2 HP Stream 13-c110nr Speakers Replacement: 步骤 9 中的图像 2,2
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Speakers Replacement: 步骤 10 中的图像 1,1
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr Speakers Replacement, Battery Assembly: 步骤 11 中的图像 1,2 HP Stream 13-c110nr Speakers Replacement, Battery Assembly: 步骤 11 中的图像 2,2
    • Use a pick to detach the Battery assembly cable.
  12. HP Stream 13-c110nr Speakers Replacement: 步骤 12 中的图像 1,2 HP Stream 13-c110nr Speakers Replacement: 步骤 12 中的图像 2,2
    • Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
    • Place eight (8) screws on magnetic mat for reassembly.
  13. HP Stream 13-c110nr Speakers Replacement: 步骤 13 中的图像 1,1
    • Remove Battery Assembly from device.
  14. HP Stream 13-c110nr Speakers Replacement, Speakers: 步骤 14 中的图像 1,2 HP Stream 13-c110nr Speakers Replacement, Speakers: 步骤 14 中的图像 2,2
    • Use a pick to disconnect the Speaker Cable from the System Board.
  15. HP Stream 13-c110nr Speakers Replacement: 步骤 15 中的图像 1,2 HP Stream 13-c110nr Speakers Replacement: 步骤 15 中的图像 2,2
    • Remove two (2) P0 PM 2.0 x 3.0 mm screws from speaker assembly.
    • Place two (2) screws on magnetic mat for reassembly.
  16. HP Stream 13-c110nr Speakers Replacement: 步骤 16 中的图像 1,1
    • Remove the Speakers from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 124
