跳转到主内容
HP Stream 11-r020nr Keyboard Panel Replacement
Will Calligan
Will Calligan3 其他贡献者
最后更新于 December 16, 2020
10 - 15 分钟
中等
This guide will show the step by step process of disassembling the HP stream in order to remove and replace the entire keyboard.
你所需要的
配件
工具
查看更多...
  1. HP Stream 11-r020nr Keyboard Panel Replacement, Keyboard Panel: 步骤 1 中的图像 1,2 HP Stream 11-r020nr Keyboard Panel Replacement, Keyboard Panel: 步骤 1 中的图像 2,2
    • Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
    • Turn the device top down so the rubber feet are facing up.
    • Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
  2. HP Stream 11-r020nr Keyboard Panel Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove all 11 of the the 5mm screws.
  3. HP Stream 11-r020nr Keyboard Panel Replacement: 步骤 3 中的图像 1,2 HP Stream 11-r020nr Keyboard Panel Replacement: 步骤 3 中的图像 2,2
    • Flip the laptop over and open the laptop.
    • Using the blue plastic opening tool, separate the keyboard plate from the main body by prying up starting around the bottom corners, prying the bottom up first and the sides second all the way around the whole keyboard plate.
    • Be gentle when lifting the keyboard up as there will be ribbon cables still attaching the keyboard to the base of the laptop.
  4. HP Stream 11-r020nr Keyboard Panel Replacement: 步骤 4 中的图像 1,2 HP Stream 11-r020nr Keyboard Panel Replacement: 步骤 4 中的图像 2,2
    • Use the black nylon spudger to flip the black tab up that holds the ribbon cable in place.
    • Lift the ribbon cable free.
  5. HP Stream 11-r020nr Keyboard Panel Replacement: 步骤 5 中的图像 1,2 HP Stream 11-r020nr Keyboard Panel Replacement: 步骤 5 中的图像 2,2
    • Use the black nylon spudger to flip the black tab up that holds the large ribbon cable in place.
    • Pull the ribbon cable free from the base of the keyboard.
  6. HP Stream 11-r020nr Keyboard Panel Replacement: 步骤 6 中的图像 1,2 HP Stream 11-r020nr Keyboard Panel Replacement: 步骤 6 中的图像 2,2
    • Remove the tape covering the ribbon cable.
    • Pull the ribbon cable away from the base of the laptop.
  7. HP Stream 11-r020nr Keyboard Panel Replacement: 步骤 7 中的图像 1,1
    • After detaching the two large ribbon cables, carefully lean the keyboard against the screen.
结论
另外一个人完成了本指南。
一条评论
Hello, I have an hp stream 11 inch laptop and would like to know how do you remove the keys from the keyboard to replace the palmrest or key board cover?
keisha manley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,782
