跳转到主内容
HP Spectre x360 15-bl012dx SSD Replacement
Cade Caldwell
Cade Caldwell5 其他贡献者
最后更新于 November 16, 2022
30 - 45 分钟
中等
If your computer is consistently crashing or having trouble booting, you could be experiencing SSD failure. Replacing the SSD will not only speed up your computer, but it should also prevent crashing. We recommend finding an external hard drive or website to upload your data onto before breaking down your computer.
Before starting this guide, please be sure to review the Troubleshooting page for extra information on an SSD.
Please note that this guide is specifically designed for the HP Spectre x360 15-bl012dx.
Before starting this repair, be sure to turn off your laptop and disconnect from the power adapter.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. HP Spectre x360 15-bl012dx SSD Replacement, Battery Replacement: 步骤 1 中的图像 1,2 HP Spectre x360 15-bl012dx SSD Replacement, Battery Replacement: 步骤 1 中的图像 2,2
    • Power off the device before beginning disassembly.
    • Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
    • Next, remove the four visible Torx T5 3 mm on the sides.
    • Keep track of all screws.
  2. HP Spectre x360 15-bl012dx SSD Replacement: 步骤 2 中的图像 1,3 HP Spectre x360 15-bl012dx SSD Replacement: 步骤 2 中的图像 2,3 HP Spectre x360 15-bl012dx SSD Replacement: 步骤 2 中的图像 3,3
    • Please note the upper two feet are already removed. The device was given to us this way.
    • Remove the two upper feet using an opening tool or spudger if they are still in place. The upper feet are closer to the hinges for the screen.
    • Remove the two 8 mm Phillips #1 screws under the feet.
    • These are the final screws to remove from the back panel. In total, you should remove eight screws between Steps 1 and 2.
  3. HP Spectre x360 15-bl012dx SSD Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to pry the back panel off of the laptop. Work your way around the perimeter of the device to loosen the connection.
    • Take the back panel off of the laptop.
  4. HP Spectre x360 15-bl012dx SSD Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove six 4 mm screws securing the battery.
  5. HP Spectre x360 15-bl012dx SSD Replacement: 步骤 5 中的图像 1,3 HP Spectre x360 15-bl012dx SSD Replacement: 步骤 5 中的图像 2,3 HP Spectre x360 15-bl012dx SSD Replacement: 步骤 5 中的图像 3,3
    • Unplug the battery connector located on the motherboard.
    • Remove the battery from the laptop.
  6. HP Spectre x360 15-bl012dx SSD Replacement, Solid State Drive (SSD): 步骤 6 中的图像 1,3 HP Spectre x360 15-bl012dx SSD Replacement, Solid State Drive (SSD): 步骤 6 中的图像 2,3 HP Spectre x360 15-bl012dx SSD Replacement, Solid State Drive (SSD): 步骤 6 中的图像 3,3
    • Using minimal force, lift the locking bars on the USB board ZIF connector using a plastic opening tool or fingernail and pull out the ribbon cable.
  7. HP Spectre x360 15-bl012dx SSD Replacement: 步骤 7 中的图像 1,1
    • Using your fingers, remove the USB ribbon cable from the motherboard above the fan.
  8. HP Spectre x360 15-bl012dx SSD Replacement: 步骤 8 中的图像 1,2 HP Spectre x360 15-bl012dx SSD Replacement: 步骤 8 中的图像 2,2
    • Remove the 3 mm Phillips #1 screw that secures the solid state drive to the board.
    • Please note this laptop was not supplied with an SSD, so this is not the same SSD you will find in your device.
  9. HP Spectre x360 15-bl012dx SSD Replacement: 步骤 9 中的图像 1,1
    • Slide the SSD card out of the connection at a 45 degree angle so that the SSD teeth are not bent.
结论
Cade Caldwell
于02/22/22注册
202 声望
创作了2篇指南
团队
Clemson, Team 1-1, Hunter Spring 2022 Clemson, Team 1-1, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S1G1
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 50
总计 2,403
