简介
This guide shows how to remove and replace the Wi-Fi card for the HP Spectre x360 15t-ap000 laptop.
The Wi-Fi card uses a standard M.2 2230 form factor with two U.FL antenna connectors. You can replace this card with any Wi-Fi card following that form factor.
你所需要的
Use a T5 driver to remove the following screws securing the back cover:
Six 4 mm-long screws
Two 7.8 mm-long screws
Use an opening tool or your fingers to pry up the back cover from the laptop.
Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
Gently pull the connector parallel to the motherboard to disconnect it.
