简介
This guide shows how to remove and replace the M.2 blade SSD for the HP Spectre x360 15t-ap000 laptop.
The laptop has a standard M.2 slot, so any M.2 form factor SSD will work with the laptop.
你所需要的
Use a T5 driver to remove the following screws securing the back cover:
Six 4 mm-long screws
Two 7.8 mm-long screws
Use an opening tool or your fingers to pry up the back cover from the laptop.
Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
Gently pull the connector parallel to the motherboard to disconnect it.
另外一个人完成了本指南。
