跳转到主内容
HP Spectre 13 4003dx x360 Battery Replacement
你所需要的
  1. HP Spectre 13 4003dx x360 Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Spectre 13 4003dx x360 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Turn the computer upside down.
    • Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
    • Make sure to use the magnetic project mat to help you keep track of the small screws.
  2. HP Spectre 13 4003dx x360 Battery Replacement: 步骤 2 中的图像 1,2 HP Spectre 13 4003dx x360 Battery Replacement: 步骤 2 中的图像 2,2
    • Use an opening tool to pry up and loosen the back case from the laptop.
    • If the back case doesn't loosen easily, there may be screws hidden underneath the rubber feet. Carefully pry a foot up and remove any hidden screws.
    • Remove the back case.
  3. HP Spectre 13 4003dx x360 Battery Replacement: 步骤 3 中的图像 1,2 HP Spectre 13 4003dx x360 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the four 2mm Phillips #00 screws securing the battery.
    • The screw locations are marked by small white arrows on the battery.
  4. HP Spectre 13 4003dx x360 Battery Replacement: 步骤 4 中的图像 1,3 HP Spectre 13 4003dx x360 Battery Replacement: 步骤 4 中的图像 2,3 HP Spectre 13 4003dx x360 Battery Replacement: 步骤 4 中的图像 3,3
    • Peel off the adhesive on the left side of the battery holding the speaker wire down.
    • Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
    • Carefully unplug the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the battery.
    • It is normal for your battery to flex and bend a bit where the wider section meets the narrower section.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
7等其他人完成本指南。
Alie Antar
于01/29/18注册
661 声望
创作了2篇指南
团队
USF Tampa, Team S5-G4, Passmore Spring 2018 USF Tampa, Team S5-G4, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S5G4
3 名成员
创作了8篇指南
5条评论
I have five T4 screws that came out without issue and three that refuse to budge. Now I am trying to figure out how to remove those without damaging the laptop itself.
fxb - 回复
Thank you! iFixit repair kit made getting the screws out easy. Now have a renewed laptop ready with 6 plus hours of battery life.
Nicholas Steblay - 回复
Tutoriel parfait, excepté peut-être qu’un double-fil côté droit de la batterie doit être libéré avant de sortir la batterie.
Bravo et merci, ça m’a tout simplement permis de me dépanner seul.
FirstName LastName - 回复
The official HP Manual (http://h10032.www1.hp.com/ctg/Manual/c04...) mentions using Torx T5 to remove the bottom cover.
Gitesh Agarwal - 回复
Thanks! I will correct the step with the right screw size.
Arthur Shi -
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 51
过去 30 天: 283
总计 22,914
