简介
If your HP ProBook 640 G2 isn't powering on, or your battery isn't charging efficiently, you may need to replace your battery. This guide will take you through each step in the process.
Before beginning this battery replacement, make sure your laptop is unplugged and powered off.
你所需要的
Flip the laptop so the bottom is facing up.
Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
Use a Torx T9 screwdriver to remove the single 6 mm screw.
Note - Be sure to dispose of your old battery responsibly! Check out iFixit's Guide on Recycling E-waste.
For optimal performance, calibrate your newly installed battery after completing this guide.
