跳转到主内容
HP Pavilion zv5000 Hard Drive Replacement
Eliza Marks
Eliza Marks3 其他贡献者
最后更新于 December 22, 2016
3 - 7 分钟
非常容易
Are you having issues saving files to your computer? Have you already tried deleting unwanted files? Replacing the hard drive may solve these issues.
你所需要的
工具
  1. HP Pavilion zv5000 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Hard Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion zv5000 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Hard Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion zv5000 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Using two fingers, pry the rest of the battery out of the socket.
  4. HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Make sure that the Pavilion is completely powered down and unplugged. Failure to do so may result in an electrical shock.
    • Using the Phillips #0 screwdriver, unscrew the two Phillips PM 2.5X6.0mm screws.
    • The two screws do not come out of the hard drive assembly, they simply disconnect the assembly from the laptop.
  5. HP Pavilion zv5000 Hard Drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion zv5000 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Place the spudger underneath the cover of the hard drive and push up gently until the hard drive pops out of place.
    • Completely remove the hard drive from its socket.
    • If the plastic spudger is not sturdy enough to pop the hard drive out of place, try carefully using the metal spudger.
结论
另外一个人完成了本指南。
Eliza Marks
于10/18/16注册
649 声望
创作了5篇指南
团队
UMass Dartmouth, Team 4-6, Catania Fall 2016 UMass Dartmouth, Team 4-6, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G6
3 名成员
创作了5篇指南
一条评论
My hp pavilion zx5000 has a blue screen and i am unable to do anything. O. S. Is Windows.
Please help
Danny Morris - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 8
过去 30 天: 15
总计 3,086
