跳转到主内容
HP Pavilion g7-2023cl Display Assembly Replacement
Thomas Maloney
Thomas Maloney 另一个贡献者
最后更新于 July 7, 2019
1小时
困难
There are a few reasons you may want to replace your display assembly. The display assembly is broken, the display assembly is punctured, most of the display assembly components are damaged, or you would rather replace the display assembly fully instead of a single component. Whatever the reason, this guide will show you how to replace the display assembly.
你所需要的
配件
工具
查看更多...
  1. HP Pavilion g7-2023cl Display Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut off your device and disconnect the power cord. Disconnect any external devices connected to the device.
    • Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
    • The lock will make a click sound letting you know that the battery is unlocked.
  2. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 2 中的图像 1,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 2 中的图像 2,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Use your thumb to pry up the edge of the battery and lift it out of the device.
    • When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure.
  3. HP Pavilion g7-2023cl Display Assembly Replacement, Service Door: 步骤 3 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement, Service Door: 步骤 3 中的图像 2,2
    • Using a Phillips #0 screwdriver, loosen the service door screw.
    • This is a captive screw that will remain attached to the service door.
  4. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 4 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 4 中的图像 2,2
    • Lift the service door up and away from the device.
  5. HP Pavilion g7-2023cl Display Assembly Replacement, Hard Drive: 步骤 5 中的图像 1,3 HP Pavilion g7-2023cl Display Assembly Replacement, Hard Drive: 步骤 5 中的图像 2,3 HP Pavilion g7-2023cl Display Assembly Replacement, Hard Drive: 步骤 5 中的图像 3,3
    • Locate the hard drive cable connector pull tab.
    • Pinch the pull tab pulling upwards from the motherboard to disconnect the hard drive cable.
    • To reconnect the cable, align it so that the cable from the connector is facing the battery and the cable lays in the groove of the base enclosure.
  6. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 6 中的图像 1,1
    • Use a spudger or other ESD-safe prying tool to lift one side of the hard drive up and out of the base enclosure.
    • You may be able to lift up the hard drive with just your fingers.
  7. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 7 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 7 中的图像 2,2
    • Grab the end of the hard drive.
    • Pull the hard drive out of the base enclosure at an angle.
    • To replace the hard drive, insert it at the same angle you removed it from and slide it back into the base enclosure until it lays flat.
  8. HP Pavilion g7-2023cl Display Assembly Replacement, Optical Drive: 步骤 8 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement, Optical Drive: 步骤 8 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the optical drive anchor screw.
  9. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 9 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 9 中的图像 2,2
    • Insert the flat end of a spudger into the optical drive release access hole.
  10. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 10 中的图像 1,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 10 中的图像 2,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 10 中的图像 3,3
    • Orient the device so that you can remove the optical drive.
    • If you are missing the bezel (face of the optical drive) or have the bezel these same steps work to remove the optical drive.
    • Using a spudger, slide out the optical drive enough so that you can grab it with your hand.
  11. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 11 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 11 中的图像 2,2
    • Remove the optical drive by pulling it out of the device.
    • When replacing the optical drive, slide it completely back into the slot so that it fits flush.
  12. HP Pavilion g7-2023cl Display Assembly Replacement, Keyboard: 步骤 12 中的图像 1,3 HP Pavilion g7-2023cl Display Assembly Replacement, Keyboard: 步骤 12 中的图像 2,3 HP Pavilion g7-2023cl Display Assembly Replacement, Keyboard: 步骤 12 中的图像 3,3
    • Locate the screw that secures the keyboard.
    • It is near the RAM module and the screw hole is identified by a keyboard symbol with the text underneath it that reads M2.5×6.5.
  13. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 13 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the Phillips M2.5×6.5 screw that secures the keyboard.
  14. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 14 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 14 中的图像 2,2
    • Insert the pointy end of a spudger into the two keyboard release holes and press down to disengage the keyboard from the device.
    • The release holes are on the base enclosure identified by a keyboard symbol with the word "release" written next to it.
  15. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 15 中的图像 1,1
    • Turn the device over and open the laptop.
  16. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 16 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 16 中的图像 2,2
    • Use your fingers and grab the corner(s) of the keyboard and lift up towards the display panel.
    • Fold the keyboard over key side down onto the top cover so that it lays flat on the track pad.
  17. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 17 中的图像 1,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 17 中的图像 2,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 17 中的图像 3,3
    • Locate the keyboard cable connector.
    • Using a plastic opening tool, flip up the locking tab on the Zero Insertion Force (ZIF) connector.
  18. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 18 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 18 中的图像 2,2
    • Pull the keyboard ribbon cable out from the connector.
  19. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 19 中的图像 1,1
    • Remove the keyboard from the device.
  20. HP Pavilion g7-2023cl Display Assembly Replacement, Upper Case Assembly: 步骤 20 中的图像 1,3 HP Pavilion g7-2023cl Display Assembly Replacement, Upper Case Assembly: 步骤 20 中的图像 2,3 HP Pavilion g7-2023cl Display Assembly Replacement, Upper Case Assembly: 步骤 20 中的图像 3,3
    • Locate the power button cable near the top left corner of the upper case assembly.
    • Using a spudger, flip up the power button ribbon cable locking tab.
  21. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 21 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, pull the power ribbon cable free from the connector.
  22. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 22 中的图像 1,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 22 中的图像 2,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 22 中的图像 3,3
    • Using tweezers or a plastic opening tool, disconnect the speaker cable from the black connector located near the right side of the laptop.
  23. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 23 中的图像 1,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 23 中的图像 2,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 23 中的图像 3,3
    • Locate the track pad cable near the track pad.
  24. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 24 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 24 中的图像 2,2
    • Using tweezers, pull the trackpad ribbon cable out from the connector on the motherboard.
  25. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 25 中的图像 1,1
    • Locate the three Phillips M2.5 x 6.5 on the upper case assembly.
  26. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 26 中的图像 1,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 26 中的图像 2,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 26 中的图像 3,3
    • Remove the three Phillips M2.5 x 6.5 screws from the upper case assembly using a Phillips #0 screwdriver.
  27. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 27 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 27 中的图像 2,2
    • Remove the upper case assembly by lifting it away from the rest of the laptop.
  28. HP Pavilion g7-2023cl Display Assembly Replacement, Display Assembly: 步骤 28 中的图像 1,3 HP Pavilion g7-2023cl Display Assembly Replacement, Display Assembly: 步骤 28 中的图像 2,3 HP Pavilion g7-2023cl Display Assembly Replacement, Display Assembly: 步骤 28 中的图像 3,3
    • Locate the display panel cable.
    • Disconnect the display panel cable.
  29. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 29 中的图像 1,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 29 中的图像 2,3 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 29 中的图像 3,3
    • Using a Phillips #0 screwdriver, remove all six screws securing the display assembly hinges to the laptop.
  30. HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 30 中的图像 1,2 HP Pavilion g7-2023cl Display Assembly Replacement: 步骤 30 中的图像 2,2
    • Lift up and remove the display assembly from the laptop.
结论
Thomas Maloney
于03/21/19注册
1,060 声望
创作了9篇指南
团队
0 Guide Comments
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 607
