跳转到主内容
HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement
Rashed
Rashed3 其他贡献者
最后更新于 June 12, 2015
20 - 30 分钟
中等
By using the following tools and the following the steps below, you can simply remove your hard drive from your HP Pavilion Sleekbook and replace it with a new one.
你所需要的
工具
  1. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Removing Keyboard: 步骤 1 中的图像 1,3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Removing Keyboard: 步骤 1 中的图像 2,3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Removing Keyboard: 步骤 1 中的图像 3,3
    • Open the laptop and locate the keyboard. Identify the borders of the keyboard.
    • Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard.
  2. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Replacing Keyboard: 步骤 2 中的图像 1,1
    • Once part of the keyboard has popped up, continue to lift the keyboard until it is removed.
  3. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Pop out the black frame found underneath the keyboard using the plastic opening tools.
    • Once the frame is popped out continue to lift the frame gently.
  4. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: 步骤 4 中的图像 1,3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: 步骤 4 中的图像 2,3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Locate and remove the silver hard drive cover in the bottom right corner.
  5. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Detach and remove the hard drive from the black plug located to the right of the hard drive.
结论
13等其他人完成本指南。
Rashed
于01/13/15注册
694 声望
撰写一个指南
团队
USF Tampa, Team 3-3, Hickman Winter 2015 USF Tampa, Team 3-3, Hickman Winter 2015 的会员
USFT-HICKMAN-W15S3G3
4 名成员
创作了5篇指南
6指南评论
Fatto per il modello 15-b131el!!
Simone Milesi - 回复
This technician has left out several crucial steps for this repair several screws on the bottom and several underneath the keyboard before the laptop casing will come apart, common sense for a tech but a how-to should not leave these details out.
dloeper2391 - 回复
These instructions ruined my friends laptops. PLEASE do not post directions like this if you don’t know what you ‘re doing as folks like me will mistakenly assume that you do & attempt this and then damage cables. VERY, VERY careful folks! Cost me $200 for a replacement laptop.
Andre Bajew - 回复
If you do not remove the screws you will crack the keyboard and cover.
HometownComputers - 回复
WIll it support any SSD drive to upgrade from basic HDD?
Gajanan Thirumoolanathan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 51
总计 17,669
