跳转到主内容
HP Pavilion 17-f004dx Screen Replacement
Chi Huynh
Chi Huynh4 其他贡献者
最后更新于 December 18, 2016
30分钟 - 1小时
困难
This guide outlines how to remove and replace your device's screen. Please follow this guide only if your original screen is beyond repair and replacement is absolutely necessary.
你所需要的
工具
查看更多...
  1. HP Pavilion 17-f004dx Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx Screen Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx Screen Replacement, CD Drive: 步骤 3 中的图像 1,1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx Screen Replacement: 步骤 4 中的图像 1,3 HP Pavilion 17-f004dx Screen Replacement: 步骤 4 中的图像 2,3 HP Pavilion 17-f004dx Screen Replacement: 步骤 4 中的图像 3,3
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx Screen Replacement, Front Panel: 步骤 5 中的图像 1,1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx Screen Replacement: 步骤 6 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx Screen Replacement: 步骤 7 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 7 中的图像 2,2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx Screen Replacement: 步骤 8 中的图像 1,1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx Screen Replacement: 步骤 10 中的图像 1,1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx Screen Replacement: 步骤 11 中的图像 1,1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx Screen Replacement: 步骤 12 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 12 中的图像 2,2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx Screen Replacement: 步骤 13 中的图像 1,1
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx Screen Replacement: 步骤 14 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 14 中的图像 2,2
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx Screen Replacement: 步骤 15 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 15 中的图像 2,2
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx Screen Replacement: 步骤 16 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 16 中的图像 2,2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
  17. HP Pavilion 17-f004dx Screen Replacement, Screen: 步骤 17 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement, Screen: 步骤 17 中的图像 2,2
    • There is a metal component connecting the screen to the casing underneath each hinge.
    • Remove three 5.6 mm screws with a Phillips 1 screwdriver on each side.
  18. HP Pavilion 17-f004dx Screen Replacement: 步骤 18 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 18 中的图像 2,2
    • Lift the black retaining flap to remove the black cable connecting the screen to the motherboard.
  19. HP Pavilion 17-f004dx Screen Replacement: 步骤 19 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 19 中的图像 2,2
    • Gently remove the black ribbon that was connected to the black flap.
  20. HP Pavilion 17-f004dx Screen Replacement: 步骤 20 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 20 中的图像 2,2
    • Locate the thin black wire that trails from the screen and remove it from the motherboard.
  21. HP Pavilion 17-f004dx Screen Replacement: 步骤 21 中的图像 1,1
    • Remove two small rubber covers on the bottom right and left edges of the screen enclosure using a metal spudger to expose two screws.
  22. HP Pavilion 17-f004dx Screen Replacement: 步骤 22 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 22 中的图像 2,2
    • Remove one 5.6mm screw with a Phillips 1 screwdriver from each side of the bottom screen.
  23. HP Pavilion 17-f004dx Screen Replacement: 步骤 23 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 23 中的图像 2,2
    • Use a metal spudger to remove the plastic casing from the perimeter of the screen.
  24. HP Pavilion 17-f004dx Screen Replacement: 步骤 24 中的图像 1,3 HP Pavilion 17-f004dx Screen Replacement: 步骤 24 中的图像 2,3 HP Pavilion 17-f004dx Screen Replacement: 步骤 24 中的图像 3,3
    • Be careful not to damage the wires.
    • Use a metal spudger to partially remove the screen from the plastic case.
  25. HP Pavilion 17-f004dx Screen Replacement: 步骤 25 中的图像 1,2 HP Pavilion 17-f004dx Screen Replacement: 步骤 25 中的图像 2,2
    • Do not touch the circuit board directly.
    • Flip the screen over and remove the tape that holds down the ribbon.
  26. HP Pavilion 17-f004dx Screen Replacement: 步骤 26 中的图像 1,1
    • Pull the ribbon away from the screen.
结论
另外一个人完成了本指南。
Chi Huynh
于09/21/16注册
726 声望
创作了2篇指南
团队
UC Davis, Team 1-4, Oliver Fall 2016 UC Davis, Team 1-4, Oliver Fall 2016 的会员
UCD-OLIVER-F16S1G4
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 21
总计 2,598
