跳转到主内容
HP Pavilion 17-f004dx RAM Replacement
Allan Soria
Allan Soria4 其他贡献者
最后更新于 December 18, 2016
20 - 45 分钟
中等
This model's RAM is located in an unusual place, underneath the motherboard. The motherboard must first be carefully lifted before you can access the RAM.
你所需要的
工具
查看更多...
  1. HP Pavilion 17-f004dx RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx RAM Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx RAM Replacement, CD Drive: 步骤 3 中的图像 1,1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx RAM Replacement: 步骤 4 中的图像 1,3 HP Pavilion 17-f004dx RAM Replacement: 步骤 4 中的图像 2,3 HP Pavilion 17-f004dx RAM Replacement: 步骤 4 中的图像 3,3
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx RAM Replacement, Front Panel: 步骤 5 中的图像 1,1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx RAM Replacement: 步骤 6 中的图像 1,2 HP Pavilion 17-f004dx RAM Replacement: 步骤 6 中的图像 2,2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx RAM Replacement: 步骤 7 中的图像 1,2 HP Pavilion 17-f004dx RAM Replacement: 步骤 7 中的图像 2,2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx RAM Replacement: 步骤 8 中的图像 1,1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx RAM Replacement: 步骤 9 中的图像 1,1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx RAM Replacement: 步骤 10 中的图像 1,1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx RAM Replacement: 步骤 11 中的图像 1,1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx RAM Replacement: 步骤 12 中的图像 1,2 HP Pavilion 17-f004dx RAM Replacement: 步骤 12 中的图像 2,2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx RAM Replacement: 步骤 13 中的图像 1,1
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx RAM Replacement: 步骤 14 中的图像 1,2 HP Pavilion 17-f004dx RAM Replacement: 步骤 14 中的图像 2,2
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx RAM Replacement: 步骤 15 中的图像 1,2 HP Pavilion 17-f004dx RAM Replacement: 步骤 15 中的图像 2,2
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx RAM Replacement: 步骤 16 中的图像 1,2 HP Pavilion 17-f004dx RAM Replacement: 步骤 16 中的图像 2,2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
  17. HP Pavilion 17-f004dx RAM Replacement, RAM: 步骤 17 中的图像 1,1
    • Remove four 5.6 mm screws with a Phillips 1 screwdriver.
    • Remove one 3 mm screw with a Phillips 1 screwdriver.
  18. HP Pavilion 17-f004dx RAM Replacement: 步骤 18 中的图像 1,2 HP Pavilion 17-f004dx RAM Replacement: 步骤 18 中的图像 2,2
    • Remove the ribbon connecting the optical drive bay to the motherboard.
  19. HP Pavilion 17-f004dx RAM Replacement: 步骤 19 中的图像 1,2 HP Pavilion 17-f004dx RAM Replacement: 步骤 19 中的图像 2,2
    • Remove the ribbon connecting the hard drive to the motherboard.
  20. HP Pavilion 17-f004dx RAM Replacement: 步骤 20 中的图像 1,2 HP Pavilion 17-f004dx RAM Replacement: 步骤 20 中的图像 2,2
    • Disconnect the ribbon from the motherboard that passes over the hard drive.
  21. HP Pavilion 17-f004dx RAM Replacement: 步骤 21 中的图像 1,2 HP Pavilion 17-f004dx RAM Replacement: 步骤 21 中的图像 2,2
    • There are still cables between the motherboard and the laptop.
    • Carefully lift the motherboard and lean it against the screen.
  22. HP Pavilion 17-f004dx RAM Replacement: 步骤 22 中的图像 1,3 HP Pavilion 17-f004dx RAM Replacement: 步骤 22 中的图像 2,3 HP Pavilion 17-f004dx RAM Replacement: 步骤 22 中的图像 3,3
    • The motherboard has two slots for the RAM. The process for removing each one is the same
    • Pull the metal tabs away from the RAM.
  23. HP Pavilion 17-f004dx RAM Replacement: 步骤 23 中的图像 1,1
    • Do not touch the circuits on the RAM. Only hold the RAM by its edges.
    • Gently remove the RAM from its slot.
结论
3等其他人完成本指南。
Allan Soria
于09/21/16注册
638 声望
创作了4篇指南
团队
UC Davis, Team 1-4, Oliver Fall 2016 UC Davis, Team 1-4, Oliver Fall 2016 的会员
UCD-OLIVER-F16S1G4
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,922
