跳转到主内容
HP Pavilion 17-f004dx Keyboard Replacement
Chi Huynh
Chi Huynh4 其他贡献者
最后更新于 December 18, 2016
30分钟 - 1小时
中等
Please note that laptop keyboard removal is not an easy process and will take time and patience, particularly when reinstalling your new keyboard.
你所需要的
工具
查看更多...
  1. HP Pavilion 17-f004dx Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx Keyboard Replacement, CD Drive: 步骤 3 中的图像 1,1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 4 中的图像 1,3 HP Pavilion 17-f004dx Keyboard Replacement: 步骤 4 中的图像 2,3 HP Pavilion 17-f004dx Keyboard Replacement: 步骤 4 中的图像 3,3
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx Keyboard Replacement, Front Panel: 步骤 5 中的图像 1,1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 6 中的图像 1,2 HP Pavilion 17-f004dx Keyboard Replacement: 步骤 6 中的图像 2,2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 7 中的图像 1,2 HP Pavilion 17-f004dx Keyboard Replacement: 步骤 7 中的图像 2,2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 8 中的图像 1,1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 9 中的图像 1,1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 10 中的图像 1,1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 11 中的图像 1,1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 12 中的图像 1,2 HP Pavilion 17-f004dx Keyboard Replacement: 步骤 12 中的图像 2,2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 13 中的图像 1,1
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 14 中的图像 1,2 HP Pavilion 17-f004dx Keyboard Replacement: 步骤 14 中的图像 2,2
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 15 中的图像 1,2 HP Pavilion 17-f004dx Keyboard Replacement: 步骤 15 中的图像 2,2
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 16 中的图像 1,2 HP Pavilion 17-f004dx Keyboard Replacement: 步骤 16 中的图像 2,2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
  17. HP Pavilion 17-f004dx Keyboard Replacement, Keyboard: 步骤 17 中的图像 1,1
    • Turn the front panel over and partially remove the clear plastic covering the keyboard casing.
  18. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 18 中的图像 1,2 HP Pavilion 17-f004dx Keyboard Replacement: 步骤 18 中的图像 2,2
    • Plastic debris may scatter while lifting the metal housing. These pieces are indicated in red.
    • Use a metal spudger to remove the metal housing from the front panel.
  19. HP Pavilion 17-f004dx Keyboard Replacement: 步骤 19 中的图像 1,2 HP Pavilion 17-f004dx Keyboard Replacement: 步骤 19 中的图像 2,2
    • Lift the metal housing from the front panel to separate the keyboard from the top panel.
结论
7等其他人完成本指南。
Chi Huynh
于09/21/16注册
726 声望
创作了2篇指南
团队
UC Davis, Team 1-4, Oliver Fall 2016 UC Davis, Team 1-4, Oliver Fall 2016 的会员
UCD-OLIVER-F16S1G4
4 名成员
创作了8篇指南
2指南评论
The main problem with this repair, is that the keyboard and laptop palmrest/bezel are a sealed unit. You have to remove dozens and dozens of little melted plastic pins to separate the metal keyboard rear plate, and dozens more plastic pins to remove the keyboard from the front bezel itself. And then getting these pins to line up again for assembly is a major PITA. I repair laptops for a living, and I will never try and replace a keyboard on this model again… its just not cost effective. I will seek out the entire keyboard/bezel unit if one of these ever comes to my shop again.
jetskier - 回复
Excellent point and observation, I have one in now for replacement and luckily had one on the shelf for parts, replacing the whole bezel and keyboard is the way to go!
timdineen -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 33
总计 5,712
