跳转到主内容
HP Pavilion 15-au123cl RAM Replacement
Mohammad Gardezi
Mohammad Gardezi 另一个贡献者
最后更新于 December 28, 2017
15 - 20 分钟
中等
By following this guide, you will be able to change the RAM sticks on your laptop. You may wish to do this if you want to upgrade the maximum RAM available or if you are noticing slowdown on your computer. You will first remove the battery before you remove the RAM.
你所需要的
工具
  1. HP Pavilion 15-au123cl RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl RAM Replacement: 步骤 2 中的图像 1,2 HP Pavilion 15-au123cl RAM Replacement: 步骤 2 中的图像 2,2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
    Correction. Top two screen pivot screws are bigger than the 8, 4mm.
    Mitchell Culp II - 回复
  3. HP Pavilion 15-au123cl RAM Replacement: 步骤 3 中的图像 1,2 HP Pavilion 15-au123cl RAM Replacement: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
    What? I think you have have neglected to mention the DVD drawer. I believe it needs to be pulled out after removing the center screw and before removing the cover.
    Dan Enslow - 回复
    Yes, best to remove the drawer as recommended. Also there are 3 screws holding the battery, not 2.
    Lastly, pay careful attention to the orientation photo when removing the back.
    I did not have the plastic tool but used a small Teflon type kitchen spatula and it did the trick. Do not use a metal screw driver or other such tool.
    Edward Yandek - 回复
  4. HP Pavilion 15-au123cl RAM Replacement: 步骤 4 中的图像 1,2 HP Pavilion 15-au123cl RAM Replacement: 步骤 4 中的图像 2,2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
    there is a third screw on bottom left of battery (in picture above)
    Paul Behrman - 回复
  5. HP Pavilion 15-au123cl RAM Replacement: 步骤 5 中的图像 1,3 HP Pavilion 15-au123cl RAM Replacement: 步骤 5 中的图像 2,3 HP Pavilion 15-au123cl RAM Replacement: 步骤 5 中的图像 3,3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl RAM Replacement, RAM: 步骤 6 中的图像 1,2 HP Pavilion 15-au123cl RAM Replacement, RAM: 步骤 6 中的图像 2,2
    • The RAM is located at the lower middle region of the motherboard.
    • Push down on the clips on both sides of the RAM stick evenly.
    • The RAM will become loose and move upward when the clips are pushed.
  7. HP Pavilion 15-au123cl RAM Replacement: 步骤 7 中的图像 1,1
    • Pull the RAM stick out of the motherboard.
    • The same steps work on both sticks of RAM.
结论
2等其他人完成本指南。
Mohammad Gardezi
于10/17/17注册
1,420 声望
创作了6篇指南
团队
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G3
2 名成员
创作了6篇指南
一条评论
Thanks mate….your steps are helpful <3
Can you please guide on how to buy the RAM for this laptop…my current RAM is 4GB
Im planning to upgrade to 8GB
thanks
Gokul Prasad Rao - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 24
总计 1,377
