跳转到主内容
HP Pavilion 15-au123cl Hard Drive Replacement
Mohammad Gardezi
Mohammad Gardezi2 其他贡献者
最后更新于 November 15, 2022
15 - 20 分钟
中等
特色学生指南
If you have noticed that your computer is no longer booting up and you have come to the conclusion that the hard drive is the problem, this guide will walk you through the sets to replace the hard drive. You will first remove the battery and then the hard drive. Using the tools suggested, you should have no problem removing the hard drive.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
查看更多...
  1. HP Pavilion 15-au123cl Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 5 中的图像 1,3 HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 5 中的图像 2,3 HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,3 HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 2,3 HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 3,3
    • The hard drive is located at the lower left area of the motherboard.
    • Using the spudger, lift the white latch holding the hard drive cable in place.
  7. HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Using the opening tool, lift the hard drive out of the motherboard.
  8. HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 8 中的图像 1,2 HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Remove the hard drive cable from the hard drive.
  9. HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 9 中的图像 1,2 HP Pavilion 15-au123cl Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Pull off the plastic wedges on both sides of the hard drive.
结论
10等其他人完成本指南。
Mohammad Gardezi
于10/17/17注册
1,420 声望
创作了6篇指南
团队
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G3
2 名成员
创作了6篇指南
一条评论
The latch on mine was black, and the socket on the m/b was white. Guess who ruined his m/b following these instructions?
TJ Fitzgerald - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 63
总计 6,983
