跳转到主内容
HP Pavilion 15-au123cl CMOS Battery Replacement
Mohammad Gardezi
Mohammad Gardezi 另一个贡献者
最后更新于 December 28, 2017
15 - 20 分钟
中等
If you are noticing the settings are wrong on the BIOS, you will want to follow this guide to reset the BIOS settings. The CMOS battery holds BIOS settings so booting up the computer after removing the battery should fix all BIOS issues.
你所需要的
工具
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
查看更多...
  1. HP Pavilion 15-au123cl CMOS Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CMOS Battery Replacement: 步骤 2 中的图像 1,2 HP Pavilion 15-au123cl CMOS Battery Replacement: 步骤 2 中的图像 2,2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CMOS Battery Replacement: 步骤 3 中的图像 1,2 HP Pavilion 15-au123cl CMOS Battery Replacement: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CMOS Battery Replacement: 步骤 4 中的图像 1,2 HP Pavilion 15-au123cl CMOS Battery Replacement: 步骤 4 中的图像 2,2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CMOS Battery Replacement: 步骤 5 中的图像 1,3 HP Pavilion 15-au123cl CMOS Battery Replacement: 步骤 5 中的图像 2,3 HP Pavilion 15-au123cl CMOS Battery Replacement: 步骤 5 中的图像 3,3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: 步骤 6 中的图像 1,2 HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: 步骤 6 中的图像 2,2
    • The CMOS battery is located toward the middle left area of the motherboard.
    • Using the spudger, lift the CMOS battery out of its plastic casing.
  7. HP Pavilion 15-au123cl CMOS Battery Replacement: 步骤 7 中的图像 1,1
    • Fully remove the CMOS battery from the motherboard.
结论
2等其他人完成本指南。
Mohammad Gardezi
于10/17/17注册
1,420 声望
创作了6篇指南
团队
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G3
2 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 45
过去 30 天: 176
总计 25,925
