跳转到主内容
HP Pavilion 15-au123cl CD Drive Replacement
Mohammad Gardezi
Mohammad Gardezi 另一个贡献者
最后更新于 December 28, 2017
15 - 20 分钟
中等
By following this guide, you will be able to replace the CD Drive. The drive is probably the easiest part to replace on the laptop.
你所需要的
工具
  1. HP Pavilion 15-au123cl CD Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CD Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion 15-au123cl CD Drive Replacement: 步骤 2 中的图像 2,2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CD Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion 15-au123cl CD Drive Replacement: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CD Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion 15-au123cl CD Drive Replacement: 步骤 4 中的图像 2,2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CD Drive Replacement: 步骤 5 中的图像 1,3 HP Pavilion 15-au123cl CD Drive Replacement: 步骤 5 中的图像 2,3 HP Pavilion 15-au123cl CD Drive Replacement: 步骤 5 中的图像 3,3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CD Drive Replacement, CD Drive: 步骤 6 中的图像 1,1
    • The CD Drive is located at the bottom right area of the motherboard.
  7. HP Pavilion 15-au123cl CD Drive Replacement: 步骤 7 中的图像 1,2 HP Pavilion 15-au123cl CD Drive Replacement: 步骤 7 中的图像 2,2
    • Disconnect the CD drive from the motherboard connector on the left.
结论
Mohammad Gardezi
于10/17/17注册
1,420 声望
创作了6篇指南
团队
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G3
2 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 18
总计 629
