跳转到主内容
HP Pavilion 15-ab165us Wi-Fi Card Replacement
Grace Chapek
Grace Chapek3 其他贡献者
最后更新于 April 6, 2019
5分钟
中等
This guide will teach you how to safely remove a defective or damaged Wi-Fi card in the HP Pavilion 15-ab165us laptop.
你所需要的
工具
查看更多...
  1. HP Pavilion 15-ab165us Wi-Fi Card Replacement, Battery and Back Cover: 步骤 1 中的图像 1,2 HP Pavilion 15-ab165us Wi-Fi Card Replacement, Battery and Back Cover: 步骤 1 中的图像 2,2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 2 中的图像 3,3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 3 中的图像 3,3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 4 中的图像 1,1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 5 中的图像 1,1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 6 中的图像 1,1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 7 中的图像 1,2 HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 7 中的图像 2,2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 8 中的图像 1,1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Wi-Fi Card Replacement, Wi-Fi Card: 步骤 9 中的图像 1,1
    • Locate the Wi-Fi card.
  10. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 10 中的图像 1,1
    • Pull the cable from the clips and use the spudger to disconnect the wire from the Wi-Fi card.
  11. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 11 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove the single 4mm screw.
  12. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 步骤 12 中的图像 1,1
    • Pull the Wi-Fi card up and out.
结论
Grace Chapek
于10/18/17注册
101 声望
撰写一个指南
团队
UW Tacoma, Team S1-G2, Rose Fall 2017 UW Tacoma, Team S1-G2, Rose Fall 2017 的会员
UWT-ROSE-F17S1G2
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 29
总计 546
