跳转到主内容
HP Pavilion 15-ab165us Fan Replacement
Chad Christy
Chad Christy 另一个贡献者
最后更新于 January 7, 2020
10 - 15 分钟
中等
需要更好的图片
This guide highlights the removal/replacement of the HP Pavilion 15-ab165us fan. The fan is a part used in electronics to dissipate heat out of the device. When the fan becomes damaged or the device stays at high temperature levels, it is recommended to replace the fan.
你所需要的
工具
查看更多...
  1. HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: 步骤 1 中的图像 1,2 HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: 步骤 1 中的图像 2,2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Fan Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-ab165us Fan Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-ab165us Fan Replacement: 步骤 2 中的图像 3,3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Fan Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15-ab165us Fan Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15-ab165us Fan Replacement: 步骤 3 中的图像 3,3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Fan Replacement: 步骤 4 中的图像 1,1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Fan Replacement: 步骤 5 中的图像 1,1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Fan Replacement: 步骤 7 中的图像 1,2 HP Pavilion 15-ab165us Fan Replacement: 步骤 7 中的图像 2,2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Fan Replacement: 步骤 8 中的图像 1,1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Fan Replacement, Fan: 步骤 9 中的图像 1,1
    • Disconnect the fan from the motherboard.
  10. HP Pavilion 15-ab165us Fan Replacement: 步骤 10 中的图像 1,3 HP Pavilion 15-ab165us Fan Replacement: 步骤 10 中的图像 2,3 HP Pavilion 15-ab165us Fan Replacement: 步骤 10 中的图像 3,3
    • Remove the the three 3mm screws with the Phillips#00 screwdriver.
  11. HP Pavilion 15-ab165us Fan Replacement: 步骤 11 中的图像 1,2 HP Pavilion 15-ab165us Fan Replacement: 步骤 11 中的图像 2,2
    • Remove the fan from the motherboard.
结论
Chad Christy
于11/07/19注册
205 声望
创作了2篇指南
团队
IUPUI, Team S3-G1, Harley Fall 2019 IUPUI, Team S3-G1, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S3G1
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 637
