跳转到主内容
HP Pavilion 15-ab165us Battery and Back Cover Replacement
Dillon Hubble
Dillon Hubble8 其他贡献者
最后更新于 April 8, 2021
10 - 15 分钟
中等
Most components that need to be replaced are inside the base of the laptop. The computer will need to be disassembled in order to reach the inner components. You will remove the battery before delving into the innards of your computer. If you just came here for a battery guide, simply follow to step two and then reassemble!
你所需要的
配件
工具
查看更多...
  1. HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: 步骤 1 中的图像 1,2 HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: 步骤 1 中的图像 2,2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 2 中的图像 3,3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 3 中的图像 3,3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 4 中的图像 1,1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 5 中的图像 1,1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 6 中的图像 1,1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 7 中的图像 1,2 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 7 中的图像 2,2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 步骤 8 中的图像 1,1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
结论
10等其他人完成本指南。
Dillon Hubble
于10/20/17注册
653 声望
创作了3篇指南
团队
UW Tacoma, Team S1-G2, Rose Fall 2017 UW Tacoma, Team S1-G2, Rose Fall 2017 的会员
UWT-ROSE-F17S1G2
5 名成员
创作了14篇指南
一条评论
Where can i buy the case? I couldn’t anywhere online??
Model - HP Pavilion 15 8th gen B&O
Jackson Beno - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 35
过去 30 天: 68
总计 66,467
