跳转到主内容
HP Pavilion 11 x360 Fan Replacement
你所需要的
  1. HP Pavilion 11 x360 Fan Replacement, Remove Screws: 步骤 1 中的图像 1,2 HP Pavilion 11 x360 Fan Replacement, Remove Screws: 步骤 1 中的图像 2,2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Fan Replacement, Remove Backing: 步骤 2 中的图像 1,3 HP Pavilion 11 x360 Fan Replacement, Remove Backing: 步骤 2 中的图像 2,3 HP Pavilion 11 x360 Fan Replacement, Remove Backing: 步骤 2 中的图像 3,3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Fan Replacement, Detach Cable: 步骤 3 中的图像 1,2 HP Pavilion 11 x360 Fan Replacement, Detach Cable: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Fan Replacement, Remove Screws: 步骤 4 中的图像 1,1
    • Remove the two 3mm screws with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: 步骤 5 中的图像 1,2 HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: 步骤 5 中的图像 2,2
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
结论
6等其他人完成本指南。
Natalie
于01/22/15注册
934 声望
创作了4篇指南
团队
Cal Poly, Team 19-9, Maness Winter 2015 Cal Poly, Team 19-9, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G9
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,496
