跳转到主内容
HP Officejet Pro 8625 Printhead Replacement
Cam Engle
Cam Engle2 其他贡献者
最后更新于 May 12, 2023
20 - 25 分钟
中等
The printhead holds the ink cartridges and is responsible for the motions that actually print documents onto paper. If you receive error messages stating that the printhead is missing or failed, use this guide to replace it. You will need a T9 Torx screwdriver for all of the screws in this guide.
你所需要的
  1. HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: 步骤 1 中的图像 1,3 HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: 步骤 1 中的图像 2,3 HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: 步骤 1 中的图像 3,3
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Printhead Replacement: 步骤 2 中的图像 1,3 HP Officejet Pro 8625 Printhead Replacement: 步骤 2 中的图像 2,3 HP Officejet Pro 8625 Printhead Replacement: 步骤 2 中的图像 3,3
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Printhead Replacement: 步骤 3 中的图像 1,2 HP Officejet Pro 8625 Printhead Replacement: 步骤 3 中的图像 2,2
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 Printhead Replacement, Printhead: 步骤 4 中的图像 1,2 HP Officejet Pro 8625 Printhead Replacement, Printhead: 步骤 4 中的图像 2,2
    • Remove the one 5.3 mm T9 screw.
  5. HP Officejet Pro 8625 Printhead Replacement: 步骤 5 中的图像 1,2 HP Officejet Pro 8625 Printhead Replacement: 步骤 5 中的图像 2,2
    • Remove the four connectors from the top of the motherboard.
  6. HP Officejet Pro 8625 Printhead Replacement: 步骤 6 中的图像 1,2 HP Officejet Pro 8625 Printhead Replacement: 步骤 6 中的图像 2,2
    • Remove the three 11.6 mm T9 screws from the top, back of the printer.
    • Remove the one 12.1 mm T9 screw from the top, back of the printer.
  7. HP Officejet Pro 8625 Printhead Replacement: 步骤 7 中的图像 1,2 HP Officejet Pro 8625 Printhead Replacement: 步骤 7 中的图像 2,2
    • Remove the 11.6mm T9 screw from the top left of the front of the printer.
  8. HP Officejet Pro 8625 Printhead Replacement: 步骤 8 中的图像 1,1
    • Disconnect the display by pulling down on the plastic hinge.
    • Gradually apply more force to the hinge and don't worry about the hinge or display breaking.
  9. HP Officejet Pro 8625 Printhead Replacement: 步骤 9 中的图像 1,3 HP Officejet Pro 8625 Printhead Replacement: 步骤 9 中的图像 2,3 HP Officejet Pro 8625 Printhead Replacement: 步骤 9 中的图像 3,3
    • Lift the display as high as it will allow to expose the back of the display.
    • Remove the connector by pinching the sides and pulling away from the printer.
    • Remove the connector by pulling both away from the display and towards the printer.
  10. HP Officejet Pro 8625 Printhead Replacement: 步骤 10 中的图像 1,2 HP Officejet Pro 8625 Printhead Replacement: 步骤 10 中的图像 2,2
    • Remove the two 11.6 mm T9 screws from beneath the display.
  11. HP Officejet Pro 8625 Printhead Replacement: 步骤 11 中的图像 1,1
    • Remove the top of the printer by lifting it from both sides.
  12. HP Officejet Pro 8625 Printhead Replacement: 步骤 12 中的图像 1,3 HP Officejet Pro 8625 Printhead Replacement: 步骤 12 中的图像 2,3 HP Officejet Pro 8625 Printhead Replacement: 步骤 12 中的图像 3,3
    • Locate the printhead on the right side of the printer.
    • Pull the white tab on the right side of the printhead up, by pushing on the side of the printer a little bit.
    • Remove the printhead by lifting it out of the housing.
结论
7等其他人完成本指南。
Cam Engle
于10/08/18注册
555 声望
创作了3篇指南
团队
Cal Poly, Team S13-G3, White Fall 2018 Cal Poly, Team S13-G3, White Fall 2018 的会员
CPSU-WHITE-F18S13G3
3 名成员
创作了14篇指南
8指南评论
This printhead is normally user replaceable.
No screwdrivers are required.
This video is for an 8600, but the process is the same.
https://www.youtube.com/watch?v=i-IluLvF...
Andy - 回复
I used these instructions to repair the guide ribbon for the print head. It had come off after a sheet of high tack labels got jammed in the printer. Just saved myself from having to buy a new printer! Thanks!!!
Robert de Salazar - 回复
12 steps not necessary. Just open the front (like changing ink) and lift the grey lever referenced in step 12, then remove the head from the carriage.
bwaaronj - 回复
Correct. So easy.
hinz -
BWAARONJ, I did exactly what you suggested in my 8625 three times! Now my printer is in pieces and parts, and I cannot get the printhead to release from the right side of the housing. I was very meticulous in making an effort to correct this problem, but, alas, it appears I will have to get a new printer!
Shelia Guy Bozeman - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 49
总计 8,358
