跳转到主内容
HP Officejet Pro 8620 CMOS Battery Replacement
Michael
Michael2 其他贡献者
最后更新于 May 9, 2023
20分钟
中等
The CMOS battery is an on board electronics memory storage battery. Removing it will reset all settings to default. If your printer frequently loses data or shuts off randomly, you may need to replace the CMOS battery.
你所需要的
  1. HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: 步骤 1 中的图像 1,3 HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: 步骤 1 中的图像 2,3 HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: 步骤 1 中的图像 3,3
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
  2. HP Officejet Pro 8620 CMOS Battery Replacement: 步骤 2 中的图像 1,2 HP Officejet Pro 8620 CMOS Battery Replacement: 步骤 2 中的图像 2,2
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 CMOS Battery Replacement: 步骤 3 中的图像 1,2 HP Officejet Pro 8620 CMOS Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 CMOS Battery Replacement: 步骤 4 中的图像 1,3 HP Officejet Pro 8620 CMOS Battery Replacement: 步骤 4 中的图像 2,3 HP Officejet Pro 8620 CMOS Battery Replacement: 步骤 4 中的图像 3,3
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
  5. HP Officejet Pro 8620 CMOS Battery Replacement, CMOS Battery: 步骤 5 中的图像 1,1
    • Gently bend the black ribbon cable by using your left hand.
    • Remove the 8mm T9-Torx screw under the black plastic cover by turning counter clockwise.
  6. HP Officejet Pro 8620 CMOS Battery Replacement: 步骤 6 中的图像 1,2 HP Officejet Pro 8620 CMOS Battery Replacement: 步骤 6 中的图像 2,2
    • Gently move the black plastic cover to the side by using your right hand.
    • Place one finger behind the top of the motherboard where you removed the previous screw.
    • Gently pull the motherboard towards you by about an inch by using your right hand's finger.
  7. HP Officejet Pro 8620 CMOS Battery Replacement: 步骤 7 中的图像 1,1
    • Gently remove the CMOS battery by using a finger from your left hand, while holding the motherboard with your right hand.
结论
5等其他人完成本指南。
Michael
于01/24/18注册
331 声望
撰写一个指南
团队
Cal Poly, Team S19-G2, Livingston Winter 2018 Cal Poly, Team S19-G2, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S19G2
3 名成员
创作了8篇指南
3条评论
I removed the lithium CMOS 3 volt battery, connected 2 wires at +(red) and - (black). Open a hole at plastic cover, and now I’m using 2 AA in serial, in a holder externally. To refill the cartridges , first open the cover till carriage stops in the middle. Second disconnect the 120 V power cable. Third remove the external CMOS 2 AA batteries, from the holder . Forth remove ink cartridges, refill and install them in the carriage. Insert exterior CMOS 2 AA batteries in the holder, Connect the power cable and you are good to go.
Arbaches Glaukus - 回复
I removed all the board fasteners to be sure. That small metal hook down below your right thumb. Be careful there no to damage the board. 10 minutes and done!
servehimdaily - 回复
Apparently the screws are T10 not T9. T9 works but you'll slightly damage the screw.
dbovey - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 81
总计 12,335
