跳转到主内容
HP Officejet J3680 Motherboard Replacement
Evan
Evan2 其他贡献者
最后更新于 May 3, 2023
15 - 30 分钟
中等
更好的介绍
你所需要的
配件
工具
  1. HP Officejet J3680 Motherboard Replacement, Unplug the Device: 步骤 1 中的图像 1,1
    • Remove the plug from the outlet and from the back of the device
    • Remove the USB Cable from your computer and from the back of the device.
  2. HP Officejet J3680 Motherboard Replacement, Remove Screws From Under the Control Panel: 步骤 2 中的图像 1,1
    • Using your Torx T10 screwdriver, remove the screws indicated in the picture. Screws are 13mm in length.
  3. HP Officejet J3680 Motherboard Replacement, Remove Screws Underneath the Ink Cartridge Cover: 步骤 3 中的图像 1,1
  4. HP Officejet J3680 Motherboard Replacement, Remove Screws from Underneath the Phone Panel: 步骤 4 中的图像 1,1
    • In step 2, you removed the screw from the blue indicated area.
    • Gently pop off the black cover that the phone rests on. Underneath this cover, you will find two more screws.
  5. HP Officejet J3680 Motherboard Replacement, Remove the Screws from the Rear of Device: 步骤 5 中的图像 1,1
  6. HP Officejet J3680 Motherboard Replacement, Remove Rear Plastic Panel: 步骤 6 中的图像 1,1
    • Once the rear plastic panel has been removed, you are ready to replace and repair the necessary parts.
  7. HP Officejet J3680 Motherboard Replacement, Remove Plugs from Main Motherboard: 步骤 7 中的图像 1,1
    • Carefully unplug all of the plugs that are connected to the main motherboard indicating in the picture.
  8. HP Officejet J3680 Motherboard Replacement, Remove Screws: 步骤 8 中的图像 1,1
    • Using your Torx t10 screwdriver, remove the 4 screws that hold the main motherboard to the device. Screws are 13mm in length.
    • Once removed, the main motherboard will be free from the device. You will notice that on the lefthand side, three of the screws hold down green wires. Make sure when replacing the motherboard that you screw these back into place.
结论
另外一个人完成了本指南。
Evan
于10/20/14注册
388 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-1, Duarte Fall 2014 UMass Dartmouth, Team 1-1, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 470
