跳转到主内容
HP LaserJet 1160 or 1320 Duplexer Gears Replacement
jdp23
jdp23
最后更新于 April 23, 2023
45分钟
简单
社区贡献指南
你所需要的
配件
工具
查看更多...
  1. HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Left Side Cover: 步骤 1 中的图像 1,3 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Left Side Cover: 步骤 1 中的图像 2,3 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Left Side Cover: 步骤 1 中的图像 3,3
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Right Side Cover: 步骤 2 中的图像 1,3 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Right Side Cover: 步骤 2 中的图像 2,3 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Right Side Cover: 步骤 2 中的图像 3,3
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Back Cover: 步骤 3 中的图像 1,3 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Back Cover: 步骤 3 中的图像 2,3 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
  4. HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Top Cover: 步骤 4 中的图像 1,3 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Top Cover: 步骤 4 中的图像 2,3 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Top Cover: 步骤 4 中的图像 3,3
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  5. HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Top Cover: 步骤 5 中的图像 1,1
    • Disconnect the control panel cable and remove the top cover.
  6. HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Fan: 步骤 6 中的图像 1,2 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Fan: 步骤 6 中的图像 2,2
    • Disconnect the fan cable from the main board of the printer.
    • Remove the retaining clip holding the fan in.
    • Remove the 2 screws holding the fan in.
  7. HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Fan Cable: 步骤 7 中的图像 1,3 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Fan Cable: 步骤 7 中的图像 2,3 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Fan Cable: 步骤 7 中的图像 3,3
    • Remove the fan cable from the cable guide.
  8. HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Duplexer PCB: 步骤 8 中的图像 1,2 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Duplexer PCB: 步骤 8 中的图像 2,2
    • Disconnect one cable from the main board of the printer.
    • Disconnect the duplexer solenoid cable from the duplexer PCB.
    • Remove one screw on the duplexer PCB and remove the PCB from the printer.
  9. HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Duplexer Gears: 步骤 9 中的图像 1,2 HP LaserJet 1160 or 1320 Duplexer Gears Replacement, Duplexer Gears: 步骤 9 中的图像 2,2
    • Remove 3 screws holding the duplexer gears to the printer and remove the gears.
结论
另外一个人完成了本指南。
jdp23
于08/22/13注册
1,312 声望
创作了23篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 814
