跳转到主内容
HP Envy m6-p114dx Speaker Replacement
Shad Padilla
Shad Padilla5 其他贡献者
最后更新于 December 6, 2022
6 - 15 分钟
中等
If the speakers in your HP Envy m6-p114dx are not producing any sound, or if they are malfunctioning and producing distorted sounds, this could be an indication that they need replacement.
This guide will show you the step by step process of removing the speaker for a HP Envy m6-p114dx to aid in either speaker replacement or removal of the hard drive. The process won’t be too difficult, requiring no special skills. Make sure to be careful when moving and removing fragile parts, because they can be fragile.
你所需要的
工具
查看更多...
  1. HP Envy m6-p114dx Speaker Replacement, Back Panel: 步骤 1 中的图像 1,3 HP Envy m6-p114dx Speaker Replacement, Back Panel: 步骤 1 中的图像 2,3 HP Envy m6-p114dx Speaker Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Power the device off, unplug it, and ground yourself.
  2. HP Envy m6-p114dx Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the twelve screws in the back case using a Phillips #1 screwdriver.
  3. HP Envy m6-p114dx Speaker Replacement: 步骤 3 中的图像 1,1
    • Carefully wedge an iFixit opening tool under the cover and slide it alongside the case to ensure that all clips are un-clipped.
  4. HP Envy m6-p114dx Speaker Replacement, Speaker: 步骤 4 中的图像 1,3 HP Envy m6-p114dx Speaker Replacement, Speaker: 步骤 4 中的图像 2,3 HP Envy m6-p114dx Speaker Replacement, Speaker: 步骤 4 中的图像 3,3
    • Unscrew the two screws that have a pink spacer below them with a Phillips #0 screwdriver.
    • Lift directly up to remove the main speaker.
    • Gently pull the wire out of the plastic track that it's set in.
  5. HP Envy m6-p114dx Speaker Replacement: 步骤 5 中的图像 1,1
    • Follow the cable around the inside of the case and remove the cable to the main board
    • Once this is removed you can fully remove the speaker!
结论
Shad Padilla
于08/26/19注册
112 声望
撰写一个指南
团队
Gateway, Team S1-G1, Saknee Fall 2019 Gateway, Team S1-G1, Saknee Fall 2019 的会员
GCC-SAKNEE-F19S1G1
2 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 225
