跳转到主内容
HP Envy dv7t-7200 Service Cover Replacement
Krystal
Krystal 另一个贡献者
最后更新于 December 29, 2017
2分钟
非常容易
Use this guide to replace a faulty service cover on your HP Envy dv7t-7200 if the back cover has been broken, damaged, or will not stay on any longer.
你所需要的
工具
  1. HP Envy dv7t-7200 Service Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Service Cover Replacement: 步骤 2 中的图像 1,3 HP Envy dv7t-7200 Service Cover Replacement: 步骤 2 中的图像 2,3 HP Envy dv7t-7200 Service Cover Replacement: 步骤 2 中的图像 3,3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Service Cover Replacement: 步骤 3 中的图像 1,1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Service Cover Replacement, Service Cover: 步骤 4 中的图像 1,1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Service Cover Replacement: 步骤 5 中的图像 1,2 HP Envy dv7t-7200 Service Cover Replacement: 步骤 5 中的图像 2,2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
结论
另外一个人完成了本指南。
Krystal
于10/16/17注册
882 声望
创作了8篇指南
团队
UW Tacoma, Team S3-G3, Liner Fall 2017 UW Tacoma, Team S3-G3, Liner Fall 2017 的会员
UWT-LINER-F17S3G3
5 名成员
创作了8篇指南
一条评论
I broke my computer. And I think it needs a new housing but I don’t know how much it costs
Elisha meyer Luwagga - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 382
