跳转到主内容
HP Envy TouchSmart 15 Battery Replacement
Robert Patterson
Robert Patterson3 其他贡献者
最后更新于 July 9, 2019
1分钟
非常容易
Replacing the battery can help with problems related to the laptop not lasting long when not plugged into the wall. You can also consider getting an extended battery to replace the original, if you need more time away from the charger.
你所需要的
  1. HP Envy TouchSmart 15 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the laptop, it will come out easily.
结论
2等其他人完成本指南。
Robert Patterson
于09/04/15注册
1,457 声望
创作了5篇指南
团队
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G6
4 名成员
创作了10篇指南
1指南评论
Can you include a source for the battery?
Beojan Stanislaus - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 3,880
